Brass Check Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2019, 08:00 AM   #1
Rewards Points: 200
Brass check valve
The brass check valve that connects to my pressure water tanks Tee needs to be replaced. The line coming in from the well is plastic and I'm not sure how to remove that connection from the brass valve.
shocker is offline   Reply With Quote
Old 02-26-2019, 09:16 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,940
Re: Brass check valve
Ayuh,.... We can't see it,...... Is it a barb connection, with hose clamps,..??
Is it a compression fittin', with a big nut,..??
Bondo is online now   Reply With Quote
Old 02-26-2019, 09:17 AM   #3
Rewards Points: 18,244
Please post a picture so we can see what your seeing.
"Plastic" could be any of at least 4 different things.
Old 02-26-2019, 09:21 AM   #4
Rewards Points: 200
Will do, thanks!
Old 02-27-2019, 05:03 PM   #5
Rewards Points: 200
Not sure of the best way to remove the valve.
Old 02-27-2019, 05:41 PM   #6
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
If there are no unions between the check valve and the point where the white pvc comes in.. then the only choice is to cut the white pvc.
Putting it back together can be done with a pvc coupling or pvc union... your choice.
Akpsdvan is offline   Reply With Quote
Old 02-27-2019, 05:50 PM   #7
Rewards Points: 200
What is the rusted metal screw sticking out of the PVC?
Old 02-27-2019, 06:29 PM   #8
Water Treatment
Akpsdvan's Avatar
Most likely you live in the north or an area that freezes.
The plug can be backed out to drain the line from the check valve back to the pump.
Old 02-27-2019, 06:36 PM   #9
Rewards Points: 3,282
I suspect at some point in time someone drilled and tapped that hole for a 1/4" national pipe thread to screw a pressure gauge in.
Old 02-28-2019, 07:30 AM   #10
Rewards Points: 200
Is this a special type of PVC pipe for water supply?
Old 02-28-2019, 05:59 PM   #11
Rewards Points: 256
It appears to be standard "Drain Waste Vent" type PVC. It's pretty crappy stuff and really shouldn't have been used there.
bfrabel is offline   Reply With Quote
Old 03-03-2019, 02:10 PM   #12
Rewards Points: 200
Is there a certain connector that you would suggest in connecting the brass valve to the PVC?
Old 03-03-2019, 02:21 PM   #13
Bondo's Avatar
Ayuh,.... If the valve is threaded, they sell pipe thread to pvc glue joint fittin's,.....
Pipe male to pvc female will glue right to the pipe,....
Old 03-06-2019, 12:42 PM   #14
Rewards Points: 200
Does it matter which side of the T valve that the pressure gauge is installed?
Old 03-08-2019, 09:28 AM   #15
Rewards Points: 200
So it doesn't matter which side of the pressure tank Tee the gauge is on? Inlet from the well or before the house supply.
Well check valve problem, well question maxalex Plumbing 7 08-21-2016 03:21 AM
condensate pump needs check valve replacement too often needsleep HVAC 13 01-15-2016 07:42 AM
Quiet Check Valve Installation shane1234 Plumbing 3 08-04-2015 06:02 PM
Check valve for tub drain? roasted Plumbing 19 01-01-2013 10:15 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
