Which Brand Of Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By hkstroud
Old 09-24-2017, 11:12 AM   #1
Rewards Points: 97
Which brand of water heater
I am having to replace our 20+ yr old Rheem propane hot water heater. The two that are available in store are A.O. Smith (Lowes) and Rheem (Home Depot). Is there one better than the other. I have heard A.O. Smith is good, but like our said, the Rheem has lasted for over 20 yrs. This is an expensive buy so I want to make sure I spend our money wisely. Thanks for any advice.
Centex2011 is offline   Reply With Quote
Old 09-24-2017, 01:01 PM   #2
hkstroud's Avatar
Rewards Points: 6,694
Re: Which brand of water heater
Suggest that you review my comments on the post below.
A water heater is just a steel tank with either electric heating elements or a gas burner. I doubt that any water heater manufacturer makes either the heating elements or the burners.
I doubt there is an iota of difference between any of the brands and a steel tank is a steel tank.
http://www.diychatroom.com/f7/upgrad...heater-547657/
Ghostmaker likes this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
