Bonus Room Toilet Still Runs Occasionally Even After New Hardware Change? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2016, 10:22 PM   #1
Rewards Points: 222
Bonus room toilet still runs occasionally even after new hardware change?
I replaced the floating hardware and the rubber flapper in a toilet however it still occasionally runs.
I'm no plumber but I'm sure it was replaced properly.
Ideas?
imola ghost is offline   Reply With Quote
Old 01-02-2016, 05:24 AM   #2
Rewards Points: 352
check the little fill hose if it is stuck in the overflow to far it can siphon.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
imola ghost (01-02-2016)
Old 01-02-2016, 05:43 AM   #3
Rewards Points: 5,590
Close the supply valve and monitor the tank water level to determine if there is a slow leak at the flapper causing the occasional running. By doing this you'll be able to determine how severe the leak is.
SeniorSitizen is offline   Reply With Quote
Old 01-02-2016, 06:39 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 802
Install a Fluidmater 400LS leak sentry fill valve.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 01-02-2016, 01:08 PM   #5
Rewards Points: 1,860
Add food dye into the tank and see if it gets to the bowel. If it does you will need to replace the flush valve.
Old 01-02-2016, 02:05 PM   #6
Rewards Points: 222
I replaced the old with this one and a red Korkey flapper.
Old 01-02-2016, 02:12 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 802
You sure you used the LS model and not the regular 400 model? The way that think works id it holds the float in the up position until the flush lever is pushed.
As Ghost said, replacing the flush valve is probably best. You have to remove the toilet tank to do that. make sure you buy replacement tank bolts.
Old 01-02-2016, 02:49 PM   #8
Rewards Points: 222
It does say 400 on the top of the floater so it might just be a 400 and not a LS.
Now I did not replace the flush valve, where you have to remove the tank. I replaced just the one going to the incoming water valve.
Old 01-02-2016, 02:51 PM   #9
Rewards Points: 222
I did go up and look at my install and it appears the water line was coming up to the very TOP of the pipe that feeds water to the bowl.
I adjusted it to be lower and hopefully this fixes the issue.
Old 01-02-2016, 03:47 PM   #10
Rewards Points: 114
If that doesn't solve it it's most likely the flush valve gasket leaking.
2x_Tom is offline   Reply With Quote
Old 01-02-2016, 04:05 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 802
Not. If the flush valve gasket leaks, the water ends up on the floor.
Old 01-02-2016, 04:18 PM   #12
Rewards Points: 114
Nope. The coupler gasket prevents that. You could flat out not install a flush valve and the water won't leak onto the floor.
Old 01-02-2016, 06:37 PM   #13
Rewards Points: 382
Also look for something stupid simple. Had one of these drove me crazy...would run fine for days, then for no reason, walk by and the toilet is still running an hour after it was flushed. The stupid chain that holds the flapper up would occasionally get caught under the flapper, allowing water to run into the bowl. Simple tweak of the chain and all set.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
The Following User Says Thank You to dougp23 For This Useful Post:
Old 01-02-2016, 07:49 PM   #14
Rewards Points: 222
I also loosened the chain one link as it seemed a little tight.
Old 01-02-2016, 08:55 PM   #15
Property Mgt/Maint
Rewards Points: 8,184
Still leaking? Do the dye test.
Changing the flush valve flapper alone doesn't always solve a leaking problem. Check the seating surface under the flapper for wear or pitting around the seat. If its worn or pitted the flapper will never seal. Would need need to replace both pcs.
[political signature removed]
Yodaman is offline   Reply With Quote
Shower in different room runs when tub runs. xinodahsnosaj Plumbing 8 02-17-2013 10:37 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
Finishing Upstairs Bonus Room luner99 Plumbing 5 02-26-2007 03:34 PM
Toilet in the same room as Oil Burner? J187 Plumbing 2 01-30-2007 07:22 PM
