Boiler Doesn't Stay On After Rad Replacement. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2015, 11:57 AM   #16
Rewards Points: 3,430
Upspete, how about another pic of the radiator that is always cold or warm at best on the top floor with the cover off. Then the techs can look at all the photos and give you better advice. Thanks.
jmon is offline   Reply With Quote
Old 01-14-2015, 12:00 PM   #17
Rewards Points: 60
Thanks jmon. The new rad is hooked up exactly like the original one. I basically just cut the old pipes and attached the new ones. The boiler shuts down at around 170 degrees.
Upspete is offline   Reply With Quote
The Following User Says Thank You to Upspete For This Useful Post:
jmon (01-14-2015)
Old 01-14-2015, 12:04 PM   #18
Thanks. 170 is fine.
Old 01-14-2015, 12:07 PM   #19
Rewards Points: 60
I think it's just air moving around. The 2nd floor bathroom rad was hot last night, cold this morning. I bled out some air and it got half warm. Waited awhile and it got cold again. Bled it some more and it got half warm again. The rest of the rads are working. The house is now up to 71 degrees. The wife and kids have stopped complaining (except for the cold bathroom). I'll wait and bleed it again later.
Old 01-14-2015, 12:20 PM   #20
Glad everything is working now. Could just be air in the lines. Thanks for the update. When bleeding the lines, start from the bottom and work up.
Old 01-14-2015, 01:37 PM   #21
Rewards Points: 60
Thanks for all your help
Old 01-14-2015, 01:48 PM   #22
Your welcome. Any problems stop by any time.
Boiler didn't stay on Jacki HVAC 0 09-27-2012 07:23 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 07:01 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
