Blue Plastic Pipe For Water Main At Residence In Washington - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2016, 06:42 PM   #16
Rewards Points: 198
Re: Blue Plastic Pipe for water main at Residence in Washington
It is leaking somewhere between the Meter and the House.
srloren is offline   Reply With Quote
Old 03-27-2016, 06:55 PM   #17
Property Mgt/Maint
Rewards Points: 8,184
Ah. Hopefully someone can pull a new line in that is attached to the old while pulling it out.
Yodaman is offline   Reply With Quote
Old 03-27-2016, 07:25 PM   #18
Rewards Points: 198
Great idea. What kind of fitting do you use to connect and be able to pull the new line through where the old line was? I don't know if he has a sandy soil but will ask him.
Old 03-27-2016, 07:37 PM   #19
Property Mgt/Maint
Not sure, never seen it done, but know it is possible. That assit. will have to come from others.
Old 03-27-2016, 09:07 PM   #20
Rewards Points: 198
Do you guys think this could be pulled through without breaking or coming apart?
Old 03-28-2016, 12:03 AM   #21
Rewards Points: 86
Here is a photo he sent me. I hope you can say what type of pipe this is. TIA
We called it PURE-CORE.
http://www.jmeagle.com/products/wate...pure-core.html
New supplier has Poly-Core or something.
ttiiggy is offline   Reply With Quote
Old 03-28-2016, 01:11 AM   #22
Rewards Points: 6,652
Originally Posted by Mort View Post
Is it C900? Its used sometimes for water around these here parts. I'm in north central Washington, but close enough.
C900 is for main and branch water mains, not from meter to house.
Old 03-28-2016, 01:13 AM   #23
Originally Posted by TheEplumber View Post
The reality is that plastic is cheaper than copper. Most installers don't care about water quality
They had to use PEX for Athens, IL, because the idiot who was water commissioner did not know about water chemistry and the water was actually eating away at Copper Piping. The Village had to go through and pull all of the Copper and put in CTS to the houses and businesses, PEX inside.
Old 03-28-2016, 01:16 AM   #24
Pure Core & Poly Core are just marketing names. It is still HDPE.
Old 03-28-2016, 10:21 AM   #25
SHEPLMBR's Avatar
Rewards Points: 178
Copper Tubing Size
around here they call it big blue. HDPE pipe
SHEPLMBR is offline   Reply With Quote
Old 03-29-2016, 11:53 PM   #26
viroid's Avatar
Here is a photo he sent me. ]
In theory that is a single piece of pipe from the meter to a fitting inside the house. Take a good look at the connection where the blue pipe meets the meter.
How bad is the leak?
Sent from my HTC One_M8 using Tapatalk
viroid is offline   Reply With Quote
Old 03-30-2016, 12:07 PM   #27
Rewards Points: 198
Actually it should be a single pipe to the Pressure Regulator. What are you looking for when you say take a look at the connection to the meter? I believe it will be either female or male ips threads that he will connect to. Thanks for your input.
How to seal a pipe through 6 mil plastic jbclem Plumbing 4 09-26-2015 06:57 PM
Which kind of pipe...What size? maddog1 Plumbing 25 08-24-2015 06:13 PM
how to remove plastic pipe on bathtub faucet beverly78 Plumbing 3 08-06-2011 08:06 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
