Black P Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2015, 01:54 PM   #1
Rewards Points: 3,209
black p trap?
Are black pipes the same as white? This one does not have the little plastic ring between the pipe and the p trap like I would expect with normal white pvc.
mathmonger is online now   Reply With Quote
Old 09-08-2015, 02:46 PM   #2
Rewards Points: 76
Black pipe is usually abs and white is pvc. I think I know what you are talking about with the "ring". I think I've seen some that the ring is kind of built into the nut that you tighten to clamp the pipe.
ponch37300 is offline   Reply With Quote
The Following User Says Thank You to ponch37300 For This Useful Post:
mathmonger (09-08-2015)
Old 09-17-2015, 03:10 PM   #3
Correcr, white is pvc, black is abs.
Sent from my SAMSUNG-SM-G900A using Tapatalk
paulliam1 is offline   Reply With Quote
The Following User Says Thank You to paulliam1 For This Useful Post:
Ron6519 (09-17-2015)
Old 09-17-2015, 03:58 PM   #4
Rewards Points: 1,952
You can use either with a mechanical joint. You cannot glue them together PVC to ABS.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Grout color for black and white wall tile mix Andiy Tiling, ceramics, marble 3 02-21-2013 09:15 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Black Iron Exposed? jamiedolan Plumbing 0 08-14-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
