Big Blue Filter Leak - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 07-06-2014, 08:55 PM   #16
Rewards Points: 208
Originally Posted by Fairview View Post
Did you replace the O ring with an OEM O ring?
Yes, I bought a new O-ring from amazon.
http://www.amazon.com/gp/product/B0025PZSSM/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
Scully is offline   Reply With Quote
Old 07-06-2014, 09:27 PM   #17
Rewards Points: 6,580
Being you have an OEM O ring, leave the filter out and tighten until the leak stops. Put a piece of tape ( masking etc. ) down the head and onto the canister. Draw a pencil line witness mark down the length of tape and then cut the tape with you pocket knife to separate the canister section and filter head. This will give you a reference mark to tighten to after the filter is installed.
The wrench provided for filters is nearly worthless. Two are needed for torque. I liked neither so I made my own since I'm a DIY kind of guy.
Old 07-06-2014, 10:07 PM   #18
Rewards Points: 208
I'm starting to wonder if the big blue filter Culligan installed for me in 2012 is actually a Pentek model. Can you guys tell from this picture if mine is a Pentek model?
Old 11-11-2017, 10:46 AM   #19
Rewards Points: 2
Smile
Re: Big Blue Filter leak
I have a long blue house filter which has seeped for a long time. We finally just put a bucket under it. In changing the filter again, I decided to google this issue, found this forum, noted the Pentek filter was too long for someone. We tested this theory by taking out the filter, screwing the blue case back in, and... NO LEAK!!. So we used our chop saw to shaved off 1/8 inch and reinstalled. It works great!!! No Leaks!!! I just joined this forum to let you all know a way to adjust the Pentek if you already have them, and to test the long filter idea first.
SeniorSitizen likes this.
SleepyCat is offline   Reply With Quote
Old 11-12-2017, 12:05 PM   #20
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
One might also look at the bottom of the sump to make sure there are no rubber seals staying at the bottom and they have also been know to stay on the head.
Another reason would be that the filter is not lining up with the head nipple when putting the sump with filter back on, if the male female do no line up it to will stop the sump from getting all the way to the closed spot.
Akpsdvan is offline   Reply With Quote
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Black material in water filter Sartrean Plumbing 4 03-09-2012 05:31 PM
Air Bear Air Filter Mr Smiley HVAC 16 08-03-2011 09:04 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Freon Leak captainron19 HVAC 3 04-16-2010 04:30 PM
