Is This The Best Way To Plumb This? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 06-17-2017, 06:17 AM   #31
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,696
Re: Is this the best way to plumb this?
Ontario code is 135° maximum bends on a run or clean out is required.
123pugsy is offline   Reply With Quote
Old 06-20-2017, 12:18 PM   #32
Rewards Points: 26
I ended up doing this one (I was informed that an emergency floor drain has 0 fixture units, so there are a max of 6 fixture units on the drain line):
The inspector and I had a discussion about whether it was acceptable and in the end he agreed that it works. Thanks for all your help!
bjfroese is offline   Reply With Quote
The Following User Says Thank You to bjfroese For This Useful Post:
123pugsy (06-20-2017)
Square and plumb a wall miamicuse Carpentry 9 01-15-2017 08:52 PM
bathtub wall board not plumb DIYer2014 Tiling, ceramics, marble 17 08-10-2014 12:15 AM
Having difficulty getting plumb cut for shed roof rafters humberguy Building & Construction 11 05-11-2012 10:32 PM
Repairing Out of Plumb Non-Flat Walls Tom5151 Building & Construction 1 12-01-2009 12:48 PM
PreHung exterior door into a not plumb opening fark Remodeling 2 10-29-2009 05:46 PM
