Best Way To Fix Leaking Abs Joint. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 10-09-2016, 12:23 PM   #1
Rewards Points: 16
Best way to fix leaking abs joint.
Hey guys. I'm doing some renovations to my house, purchased it 2 years ago. Looking for some advise.
I ripped up the laminate floor in the basement and found what looked to be a leak, so I ripped the drywall off the wall and found the clean out for my kitchen sink drain pipe leaking.
It's leaking from the top joint. Looks like someone tried to fix it by adding more glue around the joint.
Normally I would cut the whole section out and replace it, but there's not much to work with. I was thinking of cutting the fitting right below the clean out and try removing the rest, the female section, without damaging the small piece that's coming from the fitting coming out of the floor.
I never tried removing a joint. what are the chances of doing it without destroying The pipe? Is there a better way to fix this leak? I'd hate to have to break through the cement to fix this.
Any advise is greatly appreciated, thanks.
Caper79 is offline   Reply With Quote
Old 10-09-2016, 12:37 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,640
Re: Best way to fix leaking abs joint.
Cut the pipe above the clean out and get a reamer. I don't know if they can be rented.
Old 10-09-2016, 12:43 PM   #3
Rewards Points: 16
Nice, haven't seen one before. That'll be perfect, I'll look for one. Thanks a lot.
Old 10-09-2016, 01:11 PM   #4
hkstroud's Avatar
Rewards Points: 6,684
To have that much debris that joint must have never been glued. I would cut the pipe above the 45 and see if I could just pull the pipe out of the clean out hub. You may have to chisel or sand away the external glue that was applied.
If you can't just pull the pipe out of the hub, cut the pipe just above the clean out hub. Then make a couple of vertical cuts of the pipe inside the hub. With a torch begin heating the pipe inside the hub. Heat slowly. Heat and soften the entire pipe. Work a flat bladed screwdriver between the pipe and the hub and separate the two. Shouldn't be that difficult because there can't be much if any glue in the joint.
hkstroud is offline   Reply With Quote
Old 10-09-2016, 01:17 PM   #5
Rewards Points: 16
It's where the pipe goes into the clean out. Leaking at the joint.
Old 10-09-2016, 01:44 PM   #6
hkstroud's Avatar
PS
You can use a heat gun (not a hair dryer) instead of a torch to heat the pipe.
MTN REMODEL LLC likes this.
Old 10-09-2016, 02:00 PM   #7
Rewards Points: 16
My first thought was they didn't glue it, but you can see were the joint was glued, they probably just did a poor job, which seems to be the case with everything I've come across here so far.
I'll try the heat gun first, maybe the joint is bad enough it will come out with ease.
Old 10-09-2016, 02:04 PM   #8
hkstroud's Avatar
Another way.
Old 10-09-2016, 02:09 PM   #9
Super Moderator
joed's Avatar
You want to heat the inside pipe as much as possible and the clean out as little as possible. The techniques does work. I have done it. You will probably need to clean up the inside fitting with sandpaper after it comes apart.
The trick with the glue is good. I have not tried that. I used a torch, screwdriver and pliers like the video.
Old 10-09-2016, 02:11 PM   #10
Rewards Points: 16
I searched around the internet yesterday and couldn't find much. That's a neat trick to getting it out. I'll be saving that to my YouTube account.
Old 10-09-2016, 02:16 PM   #11
Rewards Points: 16
Yes, I get the idea of heating the inside pipe and keeping the outside one cool. I'm a millwright, use to working with metals instead of plastic.
Thanks for all the advise, greatly appreciate it.
Old 10-09-2016, 11:04 PM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 172
I don't know if you've started with the fire tricks yet, but for $15 bucks you can buy a Ram Bit and be done in 15 minutes or less.... no fire, no fumes.
BTW- ABS will ignite and stay burning- putting off a bad black smoke. It is different than PVC.
https://www.amazon.com/PlumBest-J440...V3W2JNQE0998FW
Old 10-10-2016, 10:36 AM   #13
hkstroud's Avatar
Thanks, didn't know that. Also didn't know ram bit was that cheap.
Old 10-10-2016, 10:41 AM   #14
Rewards Points: 16
Thanks, for the ram bit link. At that price I Think I'll pick up a couple different sizes.
Old 10-10-2016, 03:31 PM   #15
Plumber
Rewards Points: 172
They're not the best quality when compared to the 1st link, but they'll do fine for several joints
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
CBU Joint Issue? cobrakai Kitchen & Bath Remodeling 1 01-19-2011 09:11 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
soldered joint just starts leaking? red86yota Plumbing 2 05-08-2009 06:17 PM
leaking vent stack joint xrayman Plumbing 10 03-04-2008 03:23 PM
