Best Tool To Remove Hair From Clogged Bathroom Sink "elbow" In Pipe Below Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By HTFreak
  • 1 Post By Oso954
Old 09-21-2016, 08:46 AM   #1
Rewards Points: 502
Best tool to remove hair from clogged bathroom sink "elbow" in pipe below sink?
My bathroom sink has the typical "elbow/twisty" shaped to the pipe below
the sink inside the bathroom sink cabinet and I it gets clogged once every year with hair/gook etc.
What is the best solution or tool to fix this from the sink top?
(please note that one option I am trying to avoid is to take apart the "elbow/turn" pipe connections below the sink because I had a really hard time getting the pipes back together for some odd reason).
I once hired a plumber and had to pay him $50 for just a visit to clean out hair out of my shower drain, and all he did was use some kind of plastic, bendable stick with a little "hook" at the end of it. All he did was reach into shower drain pipe and use the hook on that thing to pull a giant ball of hair out with $50 in his pocket, he was on his way. Is that what I should use? If so, what is the name of it?
Or should I invest in a "snake/coil" tool? The sink hole is very small (Home Depot cheap sink).
Thanks in advance for responding to this post!!!!!!!
HTFreak is offline   Reply With Quote
Old 09-21-2016, 08:53 AM   #2
Rewards Points: 502
Re: Best tool to remove hair from clogged bathroom sink "elbow" in pipe below sink?
This is what he used I think.
http://www.homedepot.com/p/Zip-It-Ba...0400/100665735
gma2rjc likes this.
Old 09-21-2016, 08:54 AM   #3
Rewards Points: 18,976
It's called a trap, should be about 1 min. job to remove dump out and replace.
I've used on of these on a tub drain, but it's not going to be able to get it all out like removing the trap.
http://www.lowes.com/pd/Cobra-Plasti...4-9ddda1e1da36
Old 09-21-2016, 10:23 AM   #4
JUSTA MEMBER
Rewards Points: 3,914
Use "THE WORKS" toilet bowl cleaner.
Dissolves the hair, soap scum, and gunk.
$2.00 and wait a 15 minutes, then pour a pot of boiling water in the drain to flush it out.
ED
de-nagorg is offline   Reply With Quote
Old 09-21-2016, 12:41 PM   #5
Oso954's Avatar
Rewards Points: 1,868
In addition to to dropping the trap, you should also pull the pivot rod from the drain assembly, if you haven't done so. You often get a hair ball catching on the rod.
By pulling the pivot rod and pop up stopper while the trap is removed, you can look thru the vertical run, insuring it is clear.
It is often a hair ball on the pivot rod/tail of the stopper causing slow draining, not the trap.
joecaption likes this.
Oso954 is online now   Reply With Quote
Old 09-21-2016, 03:12 PM   #6
Rewards Points: 167
I just use a piece of stiff wire with a bend at the end to produce a hook.
kb3ca is offline   Reply With Quote
Old 09-21-2016, 04:54 PM   #7
Rewards Points: 1,942
Or use Bio clean with no problem again.
Old 09-21-2016, 06:11 PM   #8
Rewards Points: 116
Originally Posted by HTFreak View Post
I have long, thick hair and have to use one of these about every 2 months in the bathroom sink drain. Works great, fast and only costs a few dollars.
gma2rjc is offline   Reply With Quote
Old 09-22-2016, 09:24 PM   #9
Rewards Points: 44
I've always used a wire coat hanger with the end turned back into a hook. You might also try one of those flexible extending claw tools sold in auto parts stores.
Frank_Drebin is offline   Reply With Quote
Kitchen sink. Main pipe to wall is clogged. How to clear? Mathlete Plumbing 5 08-29-2016 01:00 PM
Replacing Some Galvanized Pipe epsilono Plumbing 6 12-03-2015 07:53 AM
Need a tool to remove a sink faucet 1-1/2" nut mystic_cobra Plumbing 6 08-26-2015 07:20 AM
Right tool to remove cartridge of single handle bath sink faucet? darsunt Plumbing 2 05-20-2011 10:01 AM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
