Bent/dinged Main Supply Pipe Through Foundation - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2015, 11:09 PM   #1
Rewards Points: 70
bent/dinged main supply pipe through foundation
The copper water supply pipe for my house has a significant ding/deformity in it right where it comes through the concrete foundation wall. (Pictures attached. It may be kind of hard to see what is going on. The wire on top is a ground wire. You can see the ding right below that.)
Is this normal/okay? Is it something I need to get fixed? (Since this is obviously before any valves or anything in my house, it would be a nightmare if it broke open or something.)
Thanks!
bent/dinged main supply pipe through foundation-img_2162.jpg   bent/dinged main supply pipe through foundation-img_2166.jpg
marmot is offline   Reply With Quote
Old 02-24-2015, 07:34 AM   #2
Rewards Points: 3,430
The pipe was probably squished by the electrician who put the ground wire clamp on.
The clamp should be moved a foot or so along the pipe further in from where it isl.
It's anyone's guess as to how long it will last before it springs a leak.
If water pressure is too low because of the constriction, you could have it fixed now.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
AllanJ is online now   Reply With Quote
Old 02-24-2015, 09:26 PM   #3
Rewards Points: 70
Alright. Thanks.
Water Main, water/sand migration through foundation wall/slab joint kos General DIY Discussions 7 03-03-2014 07:37 AM
Slimming or relocating basement main supply groove65 HVAC 13 10-07-2013 03:07 PM
Replacing main water supply line from damaged copper to pex. HitLines Plumbing 14 07-30-2013 06:09 PM
Joists, Sill Plate, Foundation and broken main beam Bonebag Building & Construction 14 02-03-2013 07:40 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
