Bending 3/4 PEX - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By DR P
Old 01-07-2018, 07:39 AM   #1
tom_poconos's Avatar
Rewards Points: 508
Unhappy
Bending 3/4 PEX
I'm working on a water filter system and I decided to use 3/4" 90 pipe supports (metal) instead of elbow joints but I'm having a lot of trouble bending the PEX into the brackets without kinking.
I'm using a heat gun which helps and also putting sand inside the PEX segment to prevent kinking. It's quite fiddly and difficult and my best attempt still has a slight kink. I could probably get away with it but I'm really not happy with the result.
Is there a secret to bending 3/4" PEX? Is there more flexible 3/4" PEX I can buy? Not having any troubles bending 1/2". I'm about to abandon the idea and just use elbow joints...
Here is the bracket:
http://www.sharkbite.com/sharkbite/w...ds/23054_3.jpg
I'm using regular 3/4" blue PEX from Lowes.
Any advice would be appreciated!
tom_poconos is offline   Reply With Quote
Old 01-07-2018, 07:52 AM   #2
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Bending 3/4 PEX
either use type A PEX or go with fittings....
no more flow loss through the 90s than would
occur in that filter cartridge as it clogs with time
what are you attempting to filter?
Peace
diyguy1 likes this.
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
tom_poconos (01-10-2018)
Old 01-07-2018, 08:15 AM   #3
Rewards Points: 508
Re: Bending 3/4 PEX
Thanks. I thought the 90s would be worthwhile due to better flow rate over elbows, but we're probably talking minuscule figures... not worth the headache?
I'm filtering well water. It's moderately hard with some sediment.
I'm doing a bunch of things in tandem - replacing an old leaking well pressure tank, adding a 3-piece (size 1 big blues) sediment filter system and adding a water softener, in three stages. And after that, replacing old copper with PEX line by line, as I slowly renovate the whole cabin.
Should be finished by 2030
Old 01-07-2018, 08:42 AM   #4
Peace be with you
DR P's Avatar
Re: Bending 3/4 PEX
how many plumbing fixtures in cabin?
if you're getting fair amount of sediment
I'd recommend a spin down filter or
possibly even a sediment trapper if needed
I'm sure there is a demo on you tube
Peace
Old 01-07-2018, 09:08 AM   #5
Rewards Points: 508
Re: Bending 3/4 PEX
There's 3 h/c taps, 1 cold tap (laundry tub), 2 toilets, 1 shower. Water heater. That's about it. The sediment isn't too bad - though it's going to be a experimental process determining what micron filters to use. The housings came with 3 filters each so I may as well start with those. I'm going to put a 150 sediment trap infront of 2 identical filters in parallel. In hindsight i should have just bought 1 large big blue instead of doing 2 smalls in parallel. Will run unfiltered water to the toilets (eventually).
Old 01-07-2018, 10:27 AM   #6
Property Mgt/Maint
Rewards Points: 8,202
Re: Bending 3/4 PEX
What you save in filter replacements you will likely make up in shortened life of the toilet, and aggravation. Hard water clogs the little flush jets that swirl the water in the bowl.
Although, you can clean them with pipe cleaners and CLR, changing a filter sounds like more fun.
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 01-10-2018, 08:25 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,140
Re: Bending 3/4 PEX
I have kinked countless sections of 3/4 pex trying to get them in those stupid supports. Had a few that kinked after being in the support for a couple of hours.
Cut out, coupling, then a 90. Gave up on them a long time ago. Didn't save much in the way of time anyway.
Journeyman Plumber
Old 01-10-2018, 10:07 PM   #8
RRH
Rewards Points: 1,480
Re: Bending 3/4 PEX
I have used plenty and never had a problem.
3/4 just takes a bit of strength to hold the bend and snap in the pipe.
Never used heat or anything else.
But I do use the plastic bends. I know I tried the metal ones years ago. Cant remember why. But I did not like or use them after trying one.
Went to the plastic ones. Use a few different brands over the years and not a problem.
I use them when I can. Less fittings the better.
And more freeze protection if ever needed. Pex can freeze and expand. But not the fittings.
Last ones I got at here
https://www.supplyhouse.com/PEX-Bend-Supports-719000
S
RRH is offline   Reply With Quote
Old 01-11-2018, 08:18 AM   #9
Rewards Points: 508
Re: Bending 3/4 PEX
You must be using PEX-A. There's no way in hell you can bend 3/4 PEX-B without a heatgun and without kinking... I abandoned my attempts and just used elbow fittings.
Old 01-11-2018, 08:48 AM   #10
RRH
Re: Bending 3/4 PEX
Not sure what you are talking about. We have been using about 15 years. With Pex B and the crimp on fitting. First started with the Zurn brand.
And never not once even considered the hassle of using a heat gun. If we had to do that in a crawl space. We would have never used the bends and just put in a fitting.
Have you tried the plastic bends. I do think they had a longer sweep bend.
Old 01-11-2018, 08:49 AM   #11
Property Mgt/Maint
Re: Bending 3/4 PEX
I have done many whole houses in pex including radiant floor heat and never once used a molded corner. Just bend the tube naturally as far as you can and attach with nail strap. Why buy extra accessories?
Old 01-11-2018, 08:50 AM   #12
Rewards Points: 6,518
Re: Bending 3/4 PEX
I've not used Pex but right or wrong or possibly inaccurate, find this article interesting. I do find it odd minimum radius for bending each size and type wasn't mentioned.
https://www.pexuniverse.com/content/types-of-pex-tubing
SeniorSitizen is offline   Reply With Quote
Old 01-11-2018, 10:29 AM   #13
RRH
Re: Bending 3/4 PEX
Because you want a tighter bend.
What is good for radiant heat is not the same.
One example. If coming out of a wall with 3/4" pex and need to bend to go down to a water heater. Or in a crawl going up in a wall. Without a bend it would look very sloppy with the extra pipe hanging down in a crawl space. Instead of nail tight up to the joist.
I just build a MDF table and its bending. How to reinforce? Dritan General DIY Discussions 24 03-20-2016 01:23 AM
Conduit bending level ponch37300 Electrical 5 11-23-2015 07:15 AM
Lineset bending problem-suggestions jfls49 HVAC 9 11-18-2012 08:03 PM
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
I keep bending blades in recip saw acerunner Tools 10 08-22-2010 11:35 AM
