Below-ground Water Shutoff Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2016, 01:19 AM   #1
Rewards Points: 327
Question
Below-ground water shutoff question
The water line running into our house has a below-ground water shutoff about halfway between the house and the street. It is like an emergency shutoff I think. There is a cap that covers a cylinder with the shutoff. I need to use it because none of the shutoffs in our house work (it's a very old house, and the water slows down but doesn't fully shut off). In order to do this I will need a water key but then which way do I turn it and how much? The thing looks so old I don't want to force it the wrong way or too much and cause a leak in it. And what if I get a leak anyway, is there some plumbers trick to stop it?
Here's what it looks like:
Deck is offline   Reply With Quote
Old 04-05-2016, 03:44 AM   #2
Rewards Points: 3,220
Re: Below-ground water shutoff question
You are correct. Those old fittings can be a pia. It can be tricky.
I would check with your local municilpality or water district first. It depends, sometimes they are resposible and will shut it off for you. If they break the curb stop, they are on the hook.
I would have a plumber standing by as you may be on the hook anyway, depends on your local municilpality. If you break something there, you got a big mess on your hands.
If you do decide to diy use an easy rocking back and forth cw/ccw motion to try and break it free. Cw will tighten (turn off) ccw will loosen(turn it on). Those water keys can be found at any big box store.
If you can, i would hire a plumber for this one. When Dealing with very old pipe, Never know whats going to happen. Especially a water main.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Deck (04-05-2016)
Old 04-05-2016, 07:40 AM   #3
Rewards Points: 258
a licensed plumber can freeze the pipe inside the house and change the mainline valve without messing with that in ground valve and save you from having to dig it up and change it if it breaks...
woodchopper65 is offline   Reply With Quote
The Following User Says Thank You to woodchopper65 For This Useful Post:
Deck (04-05-2016)
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
