Battery Sump Pump Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2015, 04:28 PM   #1
Rewards Points: 253
Battery sump pump questions
I have a Simer Ace in the Hole A5000 battery sump back up. It was time to change the battery and I bought a brand new one that was fully charged and installed it. Both the battery ready green light and yellow charge required light are on. I hit the test button and it cycled. Any ideas if anything is wrong>
If I need a replacement battery back up, any recommendations?
Ranger1227 is offline   Reply With Quote
Old 06-20-2015, 07:54 PM   #2
Rewards Points: 3,456
Verify that battery is fully charged with multimeter.
Unplug it for a minute, make sure all connections are tight, plug it back in, test again. Like a computer, sort of reboot/reset.
Link below has manuals for 5000-01, 5000-03, and 5000-04 and phone number for customer support. Just a suggestion.
Suggest the 5000-04 replacement if needed.
Others will be along with more advice/suggestions.
http://www.simerpumps.com/Residentia...01_dash03.aspx
jmon is online now   Reply With Quote
Old 06-20-2015, 08:00 PM   #3
Rewards Points: 253
Thanks. I went back to check and yellow charge light is off. I think I'm ok now
The Following User Says Thank You to Ranger1227 For This Useful Post:
jmon (06-20-2015)
Old 06-20-2015, 08:04 PM   #4
Yea, the battery probably wasn't fully charged yet. Should be good to go now.
Sump Pump Pit Alicea21 Plumbing 2 09-28-2014 08:31 AM
Continuing sump pump pipe questions Cossack Plumbing 3 05-26-2012 09:10 PM
Sump pump back up DennyF Plumbing 4 02-17-2012 01:58 PM
Sump pump questions Audioquest Plumbing 8 09-11-2010 01:40 PM
Sump Pump Battery BKUP $900. ????? roztom Plumbing 1 11-23-2009 07:53 PM
