Bathtub Trap Not Lining Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2016, 05:23 PM   #1
Lord of Slums
Rewards Points: 1,974
Bathtub trap not lining up
Typical 1950's threaded galvanized 1 1/2 pipe. Comes off the bath tub, picks up the sink and heads to the main stack. What ends up happening is I cut the tub trap out and the replacement trap does not fit.
If I tear everything out and start fresh things would line up fine. Do they make a special trap that would fit in these situations?
mj12 is offline   Reply With Quote
Old 05-05-2016, 09:11 PM   #2
Rewards Points: 18,764
Re: Bathtub trap not lining up
#1, First thing I would do is get rid of any old steel plumbing!
It is going to leak and close up on the inside at some point anyway.
First thing I do when buying houses is look at the plumbing and wiring.
Steel drains then I deduct the cost of replacing off the selling price.
Old 05-06-2016, 08:59 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 164
I don't understand how an 1.5" trap will not fit. Is it too high, too low?
My code says min 2" trap seal- 4" max seal
Old 05-06-2016, 03:45 PM   #4
Rewards Points: 1,852
Probably needs a trap adapter for the brass tub waste.
Old 05-06-2016, 06:09 PM   #5
Retired Moderator
Rewards Points: 7,174
pictures will help--there are solvent weld tub sets that would allow your to use 22 or 45 fittings to off set the drain.
Old 05-06-2016, 08:12 PM   #6
Lord of Slums
What a nightmare. Oh. Well everything is new now. That old pipe crumbed like stale bread. I had to open the wall to connect to the vent pipe.
The Following User Says Thank You to mj12 For This Useful Post:
oh'mike (05-07-2016)
Bathtub without a P Trap? bjones0216 Plumbing 3 01-07-2013 06:53 PM
do u need p trap for bathtub? oldhouse49 Plumbing 14 10-02-2011 12:32 PM
bathtub overflow drain not lining up plumbernewbie Plumbing 6 09-18-2010 05:34 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
Bathtub re-do with lining jpierce Remodeling 1 08-10-2006 05:27 PM
