Bathtub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-06-2015, 09:29 AM   #1
Rewards Points: 221
bathtub spout
One of my bathtub spouts does not work very well. The problem is exactly like that shown in the video:
. That is, the water does not get fully inverted to the shower head.
So, I ordered a Kohl spout from home depot. When I got it, I found it looks like picture 1.
Then I unscrewed my bathtub spout, only to find that it looks like picture 2.
I tried to unscrew the white stuff in the spout of picture 2, but wasn't successful.
So, how can I put on the new spout? Should I return it and get one with the white thing inside? Or should I simply buy this white stuff and put it in the new spout?
Thanks.
homenewbie is offline   Reply With Quote
Old 10-06-2015, 09:56 AM   #2
Retired Moderator
Rewards Points: 7,174
We need to know exactly what sort of pipe sticks out of the wall
Is it copper? does it have a threaded end?
What is it?
The first picture is a screw on spout---
The second picture is a 'push on' designed for a straight copper pipe (no threads)
Old 10-06-2015, 09:57 AM   #3
Rewards Points: 221
What is it?
Yes, copper, threaded. I had thought picture 2 would imply what kind of pipe I have.
Old 10-06-2015, 10:55 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,936
The one in picture 2 looks one that slips over a plain copper, seals with an o-ring and is held on by a set screw in the bottom.
#1 looks like the one that screws onto a thread fitting sticking out of the wall. They are no convertible. Get the proper one.
Old 10-06-2015, 12:44 PM   #5
Rewards Points: 221
Thanks, Joed,
Here is another picture of the type of spout shown in picture 2. I had thought that I could simply buy the white part and plug into the one I got from Kohl (picture 1).
Old 10-06-2015, 01:36 PM   #6
Rewards Points: 10,790
Rule #1 of DIY plumbing repair: first remove the problem piece and take it with you to the hardware store so you are sure you buy the correct replacement.
Get the proper one.
SPS-1 is offline   Reply With Quote
The Following 2 Users Say Thank You to SPS-1 For This Useful Post:
ben's plumbing (10-07-2015), SHR Plumber (10-06-2015)
Old 10-06-2015, 01:37 PM   #7
Rewards Points: 221
Get the proper one.
That's a great rule. Thanks. I do that that Kohl spout with me, which I will return to Home Depot today.
Old 10-06-2015, 04:28 PM   #8
Retired Moderator
A picture of the pipe would help---unfortunately the tub spouts are all a bit different--so the threaded end might be to long or to short---
Some times the stub out (pipe sticking out of the wall) is threaded on both ends--and can be removed and replaced but a proper length nipple (short threaded pipe)
Old 10-06-2015, 05:53 PM   #9
To elaborate on what Mike was saying ---- one risk you have is that you take the new spout, thread it on your pipe until its tight and its a quarter inch from touching your tub. ( or the opposite, hits the tub before its tight ) So one thing you are looking for is that the end of the spout to the start of the female thread is the same as on the old one.
The Following User Says Thank You to SPS-1 For This Useful Post:
oh'mike (10-06-2015)
broken bathtub spout DeepWoods Plumbing 8 09-28-2011 05:19 PM
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 06:39 PM
Leaky bathtub spout alacea Plumbing 0 11-29-2010 12:58 PM
Bathtub spout pipe ~ a watery mess alacea Plumbing 1 11-27-2010 12:22 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
