Bathtub Seal - How To Replace? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2015, 01:58 PM   #76
Rewards Points: 1,099
Originally Posted by Homerepairguy View Post
Oh, didn't know that you were able to install the gasket on the bottom of the tub. Even with access from the bottom it looked like since the drain goes straight down there was no way to push the pipe down to get the gasket in.
Since the pipe for the tub drain is not horizontal as shown in Tylernt's post #41 which would allow the pipe to flex upward, does the bottom of the tub flex downward to tighten the gasket underneath the tub?
Just trying to learn now,
HRG
Yes, the advantage of this setup is that the flex on the tub does compress the gasket to form an even tighter seal. But other than that the seal is formed when you screw the drain into the threaded drain shoe.
As for getting my gasket in, when I removed the wood (which was holding the drain tightly) I was able to get enough wiggle room to slide the gasket in from up top.
cjaustin81 is offline   Reply With Quote
The Following User Says Thank You to cjaustin81 For This Useful Post:
Homerepairguy (01-18-2015)
Old 01-18-2015, 08:28 PM   #77
After 7 1/2 hours not a drop of water has escaped. I used GE 100% Silicon on the drain lip.
Miami Vaulted Ceiling Insulation (need to seal?) ShenAmateur Insulation 4 08-06-2014 01:21 PM
Seal and insulate or replace ductwork? TheCheezWhiz HVAC 8 06-17-2012 08:01 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 09:27 AM
how do i replace my tubdrain and seal speedyreedy Plumbing 4 04-27-2012 08:52 AM
Replace door sill caseymax Remodeling 4 07-09-2010 12:24 PM
