Bathtub Removal Or Just The Surround? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2016, 06:58 PM   #1
Bathtub removal or just the surround?
I have a 1950's bathtub made of .... I think steel. It works ok but was wondering if I can get away with only removing the surrounding tile and drywall then replacing with better tile. It is a rental property and I don't want to spend more time or money on anything I don't have to.
What would you do? I also want to spend more time installing a shower diverter valve.
protein cop is offline   Reply With Quote
Old 03-16-2016, 07:53 AM   #2
SHEPLMBR's Avatar
Rewards Points: 178
Re: Bathtub removal or just the surround?
I would just get rid of the tile
SHEPLMBR is offline   Reply With Quote
Old 03-16-2016, 04:29 PM   #3
Rewards Points: 1,854
Are you getting any water damage around the ends of the shower curtain through the floor?
Old 03-16-2016, 05:07 PM   #4
No water damage but I will rip out the floor for new tile. It is a slab floor.
Old 03-16-2016, 06:47 PM   #5
Retired Moderator
Rewards Points: 7,174
If the tub is still in good shape, saving it is a good plan---those cast iron double skirted tubs are mighty rare---
bathtub surround leaking... sh40674 Building & Construction 6 12-02-2013 08:24 PM
Trying to decide how to do bathtub surround qoncept Remodeling 11 11-29-2012 09:59 AM
Ceramic Tile around a Surround Bathtub that has been cut LittleRascals Flooring 1 10-03-2011 12:12 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
