Bathtub Fixture Trim Spacer - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2015, 07:28 PM   #1
jelly's Avatar
Rewards Points: 360
Bathtub fixture trim spacer
I am attempting to upgrade my shower trim on an old american standard valve.
The valve comes out a little too far from the wall. When I attached the escutcheon, it sits right on the valve and I am not able to secure the escutcheon cap set.
Currently I have two escutcheons attached (one small and one large to help gain some space but it is not enough. Wondering if they make a spacer to bring the escutcheon plate out from the wall a half inch so there is room to insert the cap set into the hole.
Size:  78.1 KBName:  ImageUploadedByTapatalk1432600105.103633.jpg
jelly is offline   Reply With Quote
Old 05-26-2015, 08:12 PM   #2
jelly's Avatar
Rewards Points: 360
Does someone make a thicker escutcheon approx 1/2 - 3/4" thick? Ones I've seen are 1/4"
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 10:29 PM
Light Fixture won't turn on Jaegee Electrical 8 01-28-2013 06:25 AM
Repairing bathtub fixture skivolley Plumbing 5 02-05-2011 12:15 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
