Bathtub Faucet Is Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2015, 03:31 PM   #1
Rewards Points: 8
Bathtub faucet is leaking
I have a bathtub faucet that is leaking. It's the cold water handle. I looked up youtube.com video's on it, but can't seem to figure out how to remove this white bushing (see picture).
I've been stuck on it for an hour and giving up.
cw839 is offline   Reply With Quote
Old 09-05-2015, 03:52 PM   #2
Rewards Points: 3,430
See if you can pry it off with a small flat tip screwdriver wedge behind it. Use a little wd40 or pb blaster. Just a suggestion.
Others will be along with more suggestions.
jmon is offline   Reply With Quote
Old 09-05-2015, 04:00 PM   #3
Jello Wrangler
Rewards Points: 539
Don't start sticking screwdrivers in anything and prying. If you don't know what you are doing don't start poking at the bear, it will end up biting you.
Go to HD or Lowes and get a cartridge puller.
ChiTownPro is offline   Reply With Quote
Old 09-05-2015, 04:10 PM   #4
Rewards Points: 6,334
Have the wife pull on it while you be on stand by at the water shut off valve. Turn the water on for water pressure ( about 60 psi ) to assist her pulling and when she screams turn the supply off and the cartridge will be laying out in the tub.
A rag of some kind over the drain is always a good idea.
SeniorSitizen is offline   Reply With Quote
Old 09-05-2015, 05:02 PM   #5
Rewards Points: 8
Does the brand of cartridge puller matter? I googled the term, and lots of options come up.
Old 09-05-2015, 07:27 PM   #6
Do you know the brand of faucet.
Old 09-05-2015, 08:00 PM   #7
Rewards Points: 8
No clue to be honest. It's been in the house since we bought it (10 years ago). I've been watching other Youtube video's, and the cartridge puller looks like it has to seat/mate up to something to grab the cartridge and pull it out. Mine has nothing to seat up to.
Old 09-05-2015, 08:37 PM   #8
On some models there is a bonnet nut (see example below) that needs to be removed. It can be removed with a strap wrench (ccw). Can't tell with the picture if there is one there or not. Can you clean it up a little more and check. Thanks.
Old 09-05-2015, 09:22 PM   #9
Rewards Points: 8
Yeah, that's it for sure. It looks like the bonnet nut might be missing. I see exposed threads on top. If that's the case, should I be able to gently pry the cartridge out. I found this webpage that gave some step by steps (http://www.handymanhowto.com/remove-...lve-cartridge/)? And do I just go to Home Depot or Lowes and replace the entire unit?
Thanks a million for your help and time!
Old 09-06-2015, 08:10 AM   #10
Rewards Points: 1,932
I wonder if someone glued the cartridge in.
Old 09-06-2015, 09:39 AM   #11
Jello Wrangler
Rewards Points: 539
You are not being serious, I hope.
Sent from my SM-N910V using Tapatalk
Old 09-06-2015, 09:48 AM   #12
If you're able to identify the model there may be a rebuild kit for it. Those threads look ate up on the bottom. Could just be the picture. Might not be as bad as it looks after you clean it up.
Right at the top there is a little indentation, is there a retainer clip in there, if so remove it with a small flat tip screwdriver or needlenose pliers (careful you don't drop it down the wall) and cartridge should come out with a little wiggling. Take it to a big box, hardware or plumbing supply store to match it up.
Try removing some of that sediment calcium build up with some vinegar&water and toothbrush. Spray with some wd40 or pb blaster and let it soak for awhile.
Old 09-06-2015, 11:01 AM   #13
If that is constructed like my Delta's, a puller can be made of 2 wood screws and a piece of 3/4" wood.
Drill 2 holes 180 apart in the nylon/plastic that will allow #5 or #6 wood screws to be threaded into. Bore two holes in the wood strip equal distance of the holes in the cartridge a size that will allow the screws to slip through. Rest the wood on the stem end and screw the screws in equally to pull the cartridge bonnet.
For #5 screws probably looking at bits of 3/32" and 5/32". Test on scrap wood for fit.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
ChiTownPro (09-06-2015)
Bathtub faucet leaking majas Plumbing 3 09-25-2011 10:04 AM
how to remove plastic pipe on bathtub faucet beverly78 Plumbing 3 08-06-2011 08:06 PM
Bathtub faucet leaks from screw hole under faucet. Debmmill Plumbing 3 02-13-2011 06:43 AM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 11:08 AM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 01:50 PM
