Bathtub Draining Slowly And Can't Get Snake Through - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2015, 06:12 PM   #1
Rewards Points: 16
Bathtub draining slowly and can't get snake through
The drain to the tub has a side opening and I can only get about 6 inches of the snake through. Do I need to get a special type of snake because maybe it is a curved pipe?
guitar548 is offline   Reply With Quote
Old 06-03-2015, 06:27 PM   #2
Rewards Points: 80
Tried liquid plumber stuff? Worked great for me when i couldn't snake one of my drains. Situation was a bit different though. I used a while gallon of the stuff too.
supers05 is offline   Reply With Quote
Old 06-03-2015, 06:29 PM   #3
Rewards Points: 16
I tried liquid plumber and didn't do anything.
Old 06-03-2015, 06:40 PM   #4
Rewards Points: 6,460
Household bleach dissolves public hair.
Old 06-03-2015, 06:49 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 256
What is that picture? Is it the overflow? If so, remove the outer cover to get better access and use a 1/4" cable.
Be sure there is not a stopper and linkage in there- you will have to remove it if there is.
Also, be very careful now that you have draino in there. Drain cleaners can burn you...
Old 06-03-2015, 06:56 PM   #6
Rewards Points: 1,938
You snake through the overflow not the bottom drain of a tub.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Yodaman (06-08-2015)
Old 06-03-2015, 09:31 PM   #7
Rewards Points: 16
thanks for your help it was the stop value that needed to be taken out and replaced.
The Following User Says Thank You to guitar548 For This Useful Post:
supers05 (06-04-2015)
Old 06-08-2015, 11:31 AM   #8
Rewards Points: 198
I don't recommend using bleach around your pubic area. Could be painful!
Also if you are snaking through the overflow, you need to use a 1/4" snake because it is difficult to traverse the trap.
srloren is offline   Reply With Quote
Old 06-08-2015, 11:42 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 890
Originally Posted by srloren View Post
I don't recommend using bleach around your pubic area. Could be painfu.
Hr said public hair. I assume that on top of your head. ;-)
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 06-08-2015, 12:16 PM   #10
ZTMAN's Avatar
Rewards Points: 628
I don't let the public use my showers, so I don't have that issue
ZTMAN is offline   Reply With Quote
Tags
bathtub
