Bathtub Drain Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2016, 09:02 AM   #1
Rewards Points: 396
Bathtub drain issue
As you can see in the picture there is a purplish ring around the tub drain. It just appeared this morning. Any opinions on what this might be?
http://s1159.photobucket.com/user/mi...fjbnq.jpg.html
detroittigerfan is offline   Reply With Quote
Old 03-26-2016, 10:17 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Re: Bathtub drain issue
Ayuh,.... What color is yer soap,..??
What color is yer shampoo,..??
It ain't a drain problem,....
The Following User Says Thank You to Bondo For This Useful Post:
Nik333 (03-27-2016)
Old 03-26-2016, 10:24 AM   #3
Rewards Points: 396
their white but even it was that it would of come off with the bleach I used.
Old 03-26-2016, 10:55 AM   #4
Rewards Points: 1,852
You found them. The area 51 aliens have re-invaded.
Old 03-26-2016, 01:52 PM   #5
Rewards Points: 106
where is the top piece of the drain that screws into the shoe of the trip lever?
goobertime is offline   Reply With Quote
The Following User Says Thank You to goobertime For This Useful Post:
Yodaman (03-27-2016)
Old 03-27-2016, 07:27 AM   #6
Rewards Points: 396
excuse me??
Old 03-27-2016, 07:41 AM   #7
Property Mgt/Maint
Rewards Points: 8,184
Should be a SS strainer over the drain to catch small items dropped. The face of the flange often is not even visible with a strainer cover.
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
oh'mike (03-27-2016)
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Bathtub Drain myowneq Plumbing 7 04-06-2012 09:31 PM
separate shower and bathtub drain 23675S Plumbing 6 03-06-2012 07:43 AM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
