Bathtub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Ghostmaker
Old 04-11-2019, 11:23 AM   #1
Rewards Points: 1,080
Ok figuring out how to run the pipe for the bathroom drain got more difficult than I expected. In order to fit the trap it has to run away from the stack and make a u turn before joining unti the 3" going to the toilet. Or is there something I should do differently?Bathtub drain-20190411_071634_1554999808771.jpg
I'm just a lay person doing DIY as a loner. Eliminating K&T, L&P and sagging structure one room at a time.
WillK is online now   Reply With Quote
Old 04-12-2019, 11:23 AM   #2
Rewards Points: 685
Re: Bathtub drain
Doesn't look that far but I think better pics or diagrams would help get your point across.
huesmann is offline   Reply With Quote
Old 04-12-2019, 01:01 PM   #3
Well I'm having a heck of a time making time for this project these days with work overtime 7 days and the kids causing trouble at school.
With that said, the 3" pipe is meant to continue on to the toilet. The 2"y is meant to serve the tub. The u bend sitting next to the y roughly represents where the trap needs to sit under where the tub drain will come down.
I am thinking that the unpleasant reality is that instead of the 3" 90 coming out of the stack I probably should've used a 3" combo and then reduced to 2" on the straight. This means disassembling already glued joints.
Is there a way without disassembling already glued joints would be the question I guess.
Old 04-12-2019, 09:18 PM   #4
Rewards Points: 1,136
Re: Bathtub drain
Your wye is back wards.
Ghostmaker is online now   Reply With Quote
Old Yesterday, 02:00 PM   #5
Well I see it would be easier to connect to the tub if I turned the wye around, but code doesn't allow it to be installed the other way and I would not care to have toilet water diverted into the tub drain.
Old Today, 10:12 AM   #6
Re: Bathtub drain
Your draining the other way my mistake.
You will need to vent the tub.
TheEplumber likes this.
Old Today, 10:56 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 502
Re: Bathtub drain
I would cut the 3" San tee out. Replace it with a left hand side inlet san tee (3").
Then use the 2" side branch for the tub. It will require 2, 2" 90 as well to line up the trap.
By doing this, the tub will be vented at the 3" vent stack- assuming that's a vent and not a drain stack.
BTW, what's your plan for the clean out tee plug?
Sent from my SM-G970U using Tapatalk
Possible to snake a narrow bathtub drain from the 1960s? jbrah Plumbing 15 03-17-2019 04:58 PM
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Bathtub drain leaks crescere Plumbing 5 10-28-2014 06:09 AM
Bathtub drain replacement sharaga Plumbing 5 06-26-2014 08:05 PM
Bathtub Drain myowneq Plumbing 7 04-06-2012 09:31 PM
