Bathroom Suddenly Not Getting Water - Very Odd - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2015, 06:46 PM   #1
Rewards Points: 87
I have a bathroom whose fixtures all have been working fine. But suddenly, only hot water comes from the two sink taps (double vanity), and neither hot nor cold water comes through the tub spout. Actually, the hot drips just a little at the tub spout. Every other fixture in the house works fine. What could be causing this?
We live in the suburbs of Philadelphia, and we're experience some cold temps, but we've had temps near this before and never a problem. And why would all of the other fixtures in the house work fine except for this specific bathroom? I'm baffled... Perhaps a pipe is frozen somewhere? If not, what else could be causing this?
Chris Sweeney is offline   Reply With Quote
Old 02-16-2015, 06:51 PM   #2
Rewards Points: 10,804
The fixtures not working --- are they against an exterior wall?
SPS-1 is offline   Reply With Quote
Old 02-16-2015, 06:53 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 254
I suspect a frozen cold line. Your tub/shower is not working because it needs pressure from both hot and cold to function right
Old 02-16-2015, 06:55 PM   #4
Rewards Points: 87
No, the sink fixtures are on a wall adjacent to the exterior wall, and the tub fixture is on a wall opposite of the exterior wall. But that doesn't necessarily mean that the copper supply pipes aren't running up through the exterior wall cavity; I'm not sure of that.
Old 02-16-2015, 06:56 PM   #5
Rewards Points: 87
Is this because of the built-in mixing valve?
Old 02-16-2015, 06:59 PM   #6
Rewards Points: 48
Your pipes are freezing. I dealt with this last year and I'm only about an hour away from you. Get some heat on those pipes.
cmcnick is offline   Reply With Quote
Old 02-19-2015, 05:32 PM   #7
Rewards Points: 87
Why is this, because of the mixing valve or something?
Old 02-19-2015, 05:39 PM   #8
Rewards Points: 582
if its a newer faucet single control it is pressure balanced you need hot and cold pressure to operate properly...
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 06:42 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Running water does not go down in upstairs bathroom sink :( dnharp Plumbing 3 02-17-2013 04:37 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
