Bathroom Replumbing/Remodel - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-26-2016, 04:44 PM   #1
Rewards Points: 2
Hi, long time lurker, first time poster here.
I am working on a major remodel of my house (due to unforseen conditions of the house) and am in the middle or reworking the drainage plumbing of the two bathrooms. So far I have dry fit everything in to the best of my knowledge and I was hoping to get an extra set of eyes on my work to see if there was anything that might cause problems or me to fail the inspection
I have labeled everything and outlined the rooms in red while the room labels are in Blue
BTW the small town I live in in SE Texas uses the 2006 IRC
Any help would greatly be appreciated.
Bathroom Replumbing/Remodel-bathroom-20drainage-20plumbing-201_zpsr8uij4uy.jpg   Bathroom Replumbing/Remodel-bathroom-20drainage-20plumbing-203_zpsdmfbwe43.jpg   Bathroom Replumbing/Remodel-bathroom-20drainage-20plumbing-202_zps6ddtkv3k.jpg
wolfgard is offline   Reply With Quote
Old 06-26-2016, 07:50 PM   #2
Rewards Points: 1,852
Re: Bathroom Replumbing/Remodel
Please make sure you pull your plumbing permits for inspection. In Ohio where we use the IPC as Texas also uses you have several problems with venting. Please draw up an isometric drawing. And I will try to correct your issues to code. It is to difficult to try and type whats wrong.
Once you post an isometric I can print it then fix it and send it back to you.
Question what is a utlity closet?
Is your house a single floor slab home?
You also want to use a 3 by 4 90 when picking up toilets with the 4 inch going up for the toilet so you can easily install a toilet flange into the 4 inch.
You need to remove that flat dry vent for the last toilet farthest downstream also. No dry flat vents allowed in the IPC code.
Not sure what your intent is with that 3 inch with a 2 inch trap for Utility closet. Please explain.
Old 06-26-2016, 10:20 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
I am with Ghost You have a coupling things going on that need to be addressed
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Tags
drainage , plumbing , remodel
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 07:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
