Bathroom Remodel, Planning And Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-21-2015, 08:12 PM   #16
Property Mgt/Maint
Rewards Points: 8,202
[political signature removed]
Yodaman is offline   Reply With Quote
Old 05-21-2015, 09:20 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 276
I see one thing I don't like--
Do you have pex to the tub spout? This could cause water to dribble out the shower head when filling the tub as the pex is to restrictive- forcing water up the shower riser. It should be copper or Iron pipe to the spout.
I believe Moen actually addresses this in their install instructions- others may too.
Something to think about....
EDIT: never mind- a closer look, it appears you have copper
Old 05-22-2015, 08:44 AM   #18
Rewards Points: 114
Eplumb- This is a Delta Valve and yes its copper all the way on tub spout. Lighting just makes it look red.
cwags is offline   Reply With Quote
The Following User Says Thank You to cwags For This Useful Post:
TheEplumber (05-22-2015)
Old 05-22-2015, 10:40 AM   #19
Special User
Rewards Points: 1,230
Gosh that looks pretty.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
cwags (05-23-2015)
Old 05-23-2015, 06:49 AM   #20
Rewards Points: 114
Even though showerhead is 2.5gpm seems I'm getting more like 1.85. Is this just due to distance(2nd floor)?
Old 05-26-2015, 03:19 PM   #21
Special User
There can be various factors to this. Does the tub spout of the adjacent tub/shower also flow only 1.85GPM, or will the tub spout deliver a lot more?
Old 05-26-2015, 03:31 PM   #22
Rewards Points: 114
Tub filled almost at 5gpm
Old 05-26-2015, 04:04 PM   #23
Special User
Sounds like an issue with either the shower valve or the showerhead then. Can you take off the head to do a GPM test to isolate the problem to the valve or to the head?
Old 05-26-2015, 04:08 PM   #24
Rewards Points: 114
This is the same showerhead that feeds off the valve for tub that fills at 5gpm
Old 05-26-2015, 04:10 PM   #25
Special User
Is this a traditional diverter spout with a double-ell, or some fancy system with a separate diverter knob to turn? Does the main pressure balance (hot-cold/on-off) valve have two outlets (tub, shower) or a single outlet (tub+shower)?
Old 05-26-2015, 04:13 PM   #26
Rewards Points: 114
No just Delta 17 series. I put a cap on the tub spout when tested the showerhead as seen in pic
Old 05-26-2015, 04:18 PM   #27
Special User
Ok. I dunno much about the Delta 17, but like I said if you pull the shower head off and measure the flow rate coming out the shower riser pipe, that will tell you if the problem is in the valve (if the riser pipe delivers 1.8GPM), or in the shower head (if the riser pipe delivers 5GPM).
Old 05-26-2015, 05:19 PM   #28
Rewards Points: 114
Took showerhead off just using hose. Shower/tub got 3.1 gpm out of shower head. The master shower only got 3.75gpm. As in pic they share plumbing
Old 05-26-2015, 05:37 PM   #29
Special User
Sounds like the shower head is restrictive then. I believe federal law limits them to 2.5GPM so 1.85 is a little low. It may be clogged with debris, perhaps something left over from replumbing (copper burr or Teflon tape) or hard water deposits.
Old 05-27-2015, 03:36 PM   #30
Special User
By the way, cwags, thanks for turning me on to the Delta 17 series. I got curious and researched it, and it looks like a 17 will feature in our next bathroom remodel.
