Bathroom And Kitchen Water Line Shut Offs. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By dd57chevy
Old 01-19-2017, 12:23 PM   #1
Rewards Points: 2
Bathroom and Kitchen water line shut offs.
Where can I find bathroom and kitchen sink shut offs that won't corrode?
andyroy3 is offline   Reply With Quote
Old 01-19-2017, 09:24 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,514
Re: Bathroom and Kitchen water line shut offs.
Depends on your water. I would recommend the ball valve style as they tend to hold up better.
The Following User Says Thank You to Windows on Wash For This Useful Post:
BlackTiger (01-20-2017)
Old 01-20-2017, 08:19 AM   #3
dd57chevy's Avatar
Rewards Points: 2,986
My Dad (a union plumber) took valves apart & covered all surfaces with grease . The tub/shower valve in Mom's bathroom is vintage 1959 & works like brand new . Each time he (or I) change washers , it gets a lube job .
BlackTiger likes this.
dd57chevy is online now   Reply With Quote
Old 01-21-2017, 01:40 AM   #4
Rewards Points: 281
How often do you change the washers in the valves? Those are the 1959 valves?
Do you do this for new valves too - change washers and lube?
Druidia is offline   Reply With Quote
Old 01-21-2017, 08:54 AM   #5
dd57chevy's Avatar
My Dad was the expert , I just tried to learn (though I never really strained myself ).
He "greased" every valve he worked on . Tedious ? Yes , but when you need to change stool ball valves & the Mickey Mouse chrome shut-off valve won't work you'll wish you had ! You'll have to shut the water off to the whole house . Not really a big deal , unless you want to stay out of Divorce Court !!!
You only need to change f-washers & adjust packing nut if they drip.....
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Trouble with kitchen sink/hot water kid320 Plumbing 3 04-29-2010 10:31 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
