Bathroom Faucetrepair WITHOUT Pull Plunger/stopper? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2016, 05:40 PM   #1
Rewards Points: 222
Bathroom faucetrepair WITHOUT pull plunger/stopper?
I'm interested in these bathroom faucets at Costco. They look nice however when looking at them I noticed they did not have a way for the pull plunger to connect to.
What kind of sink or stopper do you use when the faucet doesn't have the pull stopper.
Here is a link to the product.
http://www.costco.com/.product.10014...oryTopProducts
imola ghost is offline   Reply With Quote
Old 04-18-2016, 06:08 PM   #2
Rewards Points: 109
They make pop up plungers. Push them down and they stop the drain, push down again and they release upwards
Olcrazy1 is offline   Reply With Quote
Old 04-19-2016, 08:57 AM   #3
SHEPLMBR's Avatar
Rewards Points: 178
Re: Bathroom faucetrepair WITHOUT pull plunger/stopper?
They work like tub drains sort of
SHEPLMBR is offline   Reply With Quote
Old 04-19-2016, 03:43 PM   #4
Rewards Points: 222
Got it. Thanks
Old 04-19-2016, 04:08 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
The problem with that popup is they are made for vessel sinks and do not have an overflow drain slot.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 04-19-2016, 10:28 PM   #6
Rewards Points: 38
According to the ad copy in the link you posted, the drain assembly is in the box with the faucet. No need for an additional drain.
SHR Plumber is offline   Reply With Quote
Old 04-20-2016, 05:32 AM   #7
SHEPLMBR's Avatar
Rewards Points: 178
They do make some with overflow holes. Danze has a whole line of them
Old 04-21-2016, 07:14 AM   #8
Rewards Points: 1,262
I'd have a problem when I have to use my hand to open the stopper, then rinse again. Also, I put new American Standard vanity faucet with cable operated stopper. The stopper is a standard one, but it is still heavy enough to push down on its own. It is enough to create a poor drain. This faucet also has flex supply with little more than 1/8 i.d. tubes. When toilet is flushed, it gets no cold water.
carpdad is offline   Reply With Quote
Old 04-21-2016, 07:42 AM   #9
SHEPLMBR's Avatar
Rewards Points: 178
The picture you showed, shows it should have a pop up. is there a removable plug on the back side of faucet? Why did it not come with the pop up?
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 07:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 10:50 AM
adding wall switch to pull chain light, gone wrong. dim chandelier Electrical 4 01-28-2013 08:07 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
