Bathroom Drain Stub-out What To Do If Glued - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2016, 07:17 PM   #76
Rewards Points: 582
Originally Posted by french_guy View Post
Yeah, I know....
1 more question: Is it OK to cap a 1 1/2" drain line - inside a wall - with this:
http://www.homedepot.com/p/1-1-2-in-...-101/100372302
Or I have to go with the glued PVC cap?
why would you want too?????
Old 02-21-2016, 07:43 PM   #77
Rewards Points: 1,330
Because I'm decommissioning an old vanity.....
french_guy is offline   Reply With Quote
Old 02-22-2016, 10:01 AM   #78
Actually, I want to cap that one off (inside the wall)
Old 03-03-2016, 05:38 AM   #79
Anybody?
Old 03-03-2016, 07:21 AM   #80
Retired Moderator
Rewards Points: 7,174
Yes, you can cut and cap that inside the wall---Please use a PVC cap --primed and glued (solvent weld)---it is cheaper than a rubber cap and eliminates the possibility of a failure--
Old 04-20-2016, 08:19 PM   #81
Re: bathroom drain stub-out what to do if glued
Originally Posted by ben's plumbing View Post
wow ..just open the wall ..not a big deal.. looks like you already have an 1 1/2 vent ..so do it the better way....sorry..
OK, I had to put on hold this project for a while
Old vanity has been removed, and floor has been tiled
The 2 pieces of blue tape represents the axis of the sinks
The new vanity (combination of IKEA kitchen cabinet 96 long: 15 + 24 +18 + 24 +15) will be centered over the heat register
How should the waste line be modified to install 2 sinks (will be inside the wall)
Old 05-10-2016, 08:27 AM   #82
I cut open a portion of the wall. Still need to cut 1 more cavity on the right, but it gives an idea.
How should I proceed now? Do i use this:
http://www.homedepot.com/p/1-1-2-in-...D112/100678015
Once glued on the bottom of my existing drain (instead of the Tee), how do I attach it to the vent on the top?
My wall is 2x4 studs....Should I use stud shoes on the 2 studs I will have to drill or notch on the right side?
bathroom drain stub-out what to do if glued-img_1522.jpg   bathroom drain stub-out what to do if glued-img_1523.jpg
Old 05-10-2016, 02:27 PM   #83
Rewards Points: 1,862
Wow that 8 inch deep ptrap will work just great.... NOT
Old 05-10-2016, 02:38 PM   #84
What do you mean???
Old 05-10-2016, 08:03 PM   #85
Plumber
TheEplumber's Avatar
Rewards Points: 174
You need to put the fitting in the vertical pipe. Then drill and run the trap arms to the desired sink locations. Use nail guards when drilling within 1.5" of the stud surface.
To throw a wrench into your plan- The code I use will not accept the cross you picture and I could only put 1 lav on 1.5" pipe. So I suggest you research what your local code allows- just to be sure....
Old 05-10-2016, 08:59 PM   #86
I really don't see how i could replace that 1.5" drain by a 2"......so does that mean i'm screwed?
Old 05-10-2016, 09:13 PM   #87
Plumber
Rewards Points: 174
No, it just means that you're trying to drain 2 lavs into a pipe typically sized for 1.
The 1.5" cross will allow some water to wash across the fitting towards the other sink too.
What I'd do is use 2- 1.5" san tees stacked on top each other and pointed in opposing directions. This will affect the trap height at each lav though- one will be a couple inches higher- find a happy medium and it should work
Old 05-11-2016, 05:33 AM   #88
Great, thanks
The sink on the left is very close to the current vertical drain. The one on the right will be farther, something like 32"
Is there an angle on the horizontal hub? I will put the sanitary T for the right sink on the bottom, and the left on the top
Then that angle (over the 36") might help to compensate the height difference of the stub-out.....
By the way, gluing the 1st san Tee on the vertical drain line is easy, and the 2nd san Tee on top of the 1st one as well....But how do I connect the vent back to the top of the 2nd Tee? It would need to be lifted up, then down to slide inside the hub, but I guess it doesn't move, right?
Old 05-11-2016, 06:59 AM   #89
Plumber
Rewards Points: 174
Pitch the pipe at 1/4" per ft. That will gain you 3/4"
When you cut the vertical pipe, there is a good chance it will lift enough. If not, you should be able to find a repair coupling- it doesn't have an interior pipe stop. So it can slide up the pipe, then back down on the other piece when assembling
Old 05-11-2016, 07:26 AM   #90
Is this repair coupling in rubber, and attach with clamp?
Or is it PVC to be glued? Might not be easy to glue on top and bottom at the same time.....
Basic Question on plumbing (planning to unclog bathroom sink drain) babyfishmouth Plumbing 1 07-31-2011 12:14 AM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 09:52 AM
Bathroom Sinks do not line up with drain pipe - what do I do? mark2741 Plumbing 7 04-15-2010 07:11 PM
bees in bathroom (drain pipe) foxsam Pest Control 4 12-15-2009 06:22 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
