Bathroom Drain Stub-out What To Do If Glued - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2016, 10:22 AM   #61
Rewards Points: 1,326
What is the difference between this:
http://www.lowes.com/pd_24372-143-85...=R#reviews_tab
and this:
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
other than the $20 difference....!!!!
french_guy is offline   Reply With Quote
Old 02-17-2016, 11:28 AM   #62
Rewards Points: 3,202
and this:
This has come up before on this forum for discussion. I believe the mechanical type is spring operated and the other type is gravity operated. Or it's the other way around - one of the plumbers here will know and let you know which is better.
But I agree with you, they both do the same thing.
Depends on location if you can use them or not. I've seen them used in mobile homes, regular homes and RV's. Check your local code office for sure.
jmon is online now   Reply With Quote
Old 02-17-2016, 12:12 PM   #63
WhatRnsdownhill's Avatar
Rewards Points: 2,220
and this:
one is a piece of crap and one will work for many years without problems and lets in the correct amount of air....spend the extra money..studor vent http://www.amazon.com/Studor-20346-R...ds=studor+vent is the same cheaper on amazon..
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
jmon (02-17-2016)
Old 02-17-2016, 12:21 PM   #64
OK, I went at Home Depot and got some PVC fittings to see how it will "look like"
I will post a picture tonight to show you......
Old 02-17-2016, 12:34 PM   #65
should I have a few drinks first??
Old 02-17-2016, 12:41 PM   #66
Not too much, otherwise you will mix straight pipes with 45 or 22.....
Old 02-17-2016, 06:48 PM   #67
Here are the pictures....1st one is to show the assembly and 2nd one to show how it will fit in the cabinet
Is this what you explained?
bathroom drain stub-out what to do if glued-img_1349.jpg   bathroom drain stub-out what to do if glued-img_1350.jpg
Old 02-18-2016, 07:58 PM   #68
yes, that is it, if you needed it over some more , use a regular 45 and put a 3 inch or so piece between the 45 and 90..
Old 02-18-2016, 08:09 PM   #69
Can i replace the 45 by a 90 if i want the TY closer to the back wall?
And can i use this to do the connection with that whole assemnly onto the drain coming out of the wall:http://www.homedepot.com/p/1-1-2-in-...-150/100058870
Or even the one with the metal jacket around it?
Old 02-18-2016, 08:16 PM   #70
you can use a no hub clamp and since you will have a clamp and way to clean the pipe if need be, you can use the 2 90s together, but you try and stay away from making quick double bends like that in the drain..you probably will never have an issue..
Old 02-18-2016, 08:21 PM   #71
So you are saying i should avoid the 2x90, or you mean i should be ok?
Old 02-18-2016, 10:13 PM   #72
it should be fine....
Old 02-19-2016, 05:55 PM   #73
Rewards Points: 582
wow ..just open the wall ..not a big deal.. looks like you already have an 1 1/2 vent ..so do it the better way....sorry..
Old 02-19-2016, 07:37 PM   #74
I been telling him that all along, but wanted this way, I think hes getting the plumber to move the pipes in the wall..
ben's plumbing (02-19-2016)
Old 02-21-2016, 04:13 PM   #75
Yeah, I know....
1 more question: Is it OK to cap a 1 1/2" drain line - inside a wall - with this:
http://www.homedepot.com/p/1-1-2-in-...-101/100372302
Or I have to go with the glued PVC cap?
Basic Question on plumbing (planning to unclog bathroom sink drain) babyfishmouth Plumbing 1 07-31-2011 12:14 AM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 09:52 AM
Bathroom Sinks do not line up with drain pipe - what do I do? mark2741 Plumbing 7 04-15-2010 07:11 PM
bees in bathroom (drain pipe) foxsam Pest Control 4 12-15-2009 06:22 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
