Bath Tub Drain Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2016, 11:50 AM   #1
Rewards Points: 740
Bath tub drain leaks
I have installed three bathtubs now and I always have a problem with water leaking from the bottom drain underneath the tub. I line up the drain with the PVC pipe and tighten it with a fork style wrench. I place clear silicone caulk underneath the drain first. Should I use Plumbers putty instead? Any pointers would be appreciated.
crescere is offline   Reply With Quote
Old 01-18-2016, 11:54 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
I don't believe in silicone for plumbing work. I'm not a plumber so they may disagree. I've used plumbers putty only with no issues.
Did you install the rubber washer between the tub and drain flange?
123pugsy is offline   Reply With Quote
Old 01-18-2016, 12:03 PM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
plumbers putty is old school, it dries out and leaks and the oils in it can leach into marble, granite and some of the man made materials used for tubs and sinks, silicone is the way togo..once hardened it wont go anywhere, use afta cleaning fluid to clean it up, works great... as far as your leak, make sure the rubber gasket is on the bottom and you tighten the threaded drain piece into the shoe of the trip lever...a small bead of silicone holds the bottom gasket on the shoe and another bead around the threaded drain piece...
WhatRnsdownhill is offline   Reply With Quote
The Following 4 Users Say Thank You to WhatRnsdownhill For This Useful Post:
JERRYMAC (01-20-2016), jmon (01-18-2016), oh'mike (01-18-2016), TheEplumber (01-18-2016)
Old 01-18-2016, 12:16 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 168
I'm mostly a silcone guy too. Too many call backs from putty, especially during rough in's in sub freezing temps.
What W&O assemblies are you using?
The Following User Says Thank You to TheEplumber For This Useful Post:
jmon (01-18-2016)
Old 01-18-2016, 12:33 PM   #5
Rewards Points: 3,218
deleted.
jmon is online now   Reply With Quote
Old 01-18-2016, 12:40 PM   #6
another reason for silicone, all the cheap plastic components made today would break if you tightened them down enough to squeeze out plumbers putty....the old solid brass drains and faucets could be cranked down tight and not give or break...
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
Old 01-18-2016, 02:14 PM   #7
Retired Moderator
Rewards Points: 7,174
Just a heads up---sometime the leak is from the overflow gasket---those often don't show up for a while---are you sure the leak is from the bottom of the tub?
Old 01-18-2016, 06:14 PM   #8
Rewards Points: 1,856
Did you use a water based (latex) silicon caulk? You need to use 100% clear silicon caulk.
http://www.lowes.com/pd_51220-72643-...5-00007b120833
Old 01-19-2016, 05:09 AM   #9
123pugsy's Avatar
It seems all the pros like silicone.
Do you need to wait 24 hours before checking for leaks?
Old 01-19-2016, 05:39 AM   #10
Retired Moderator
You can test the assembly right away---the rubber gasket below the tub is the real water tight seal---
Leaks are often caused when the bottom of the hole is not absolutely smooth--
Bits of old gasket---drips of glaze---any bump can cause a gasket to not fully seat.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
123pugsy (01-19-2016), JERRYMAC (01-20-2016)
Old 01-19-2016, 05:51 PM   #11
Actually water makes silicon caulk hard.
Broke off my bath tub drain JeffW650 Plumbing 16 01-31-2014 08:59 PM
New bath waste line leaks Klawman Plumbing 21 03-22-2013 09:44 PM
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 09:02 AM
ABS drain pipe leaks under pressure test abracaboom Plumbing 12 01-24-2012 07:27 PM
Bath tub Drain not stopping water 100% to fill tub superdairyboy Plumbing 5 02-13-2010 10:53 PM
