Bath Room Vent - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By jimn01
  • 1 Post By Ghostmaker
Old 06-15-2016, 02:09 PM   #1
Rewards Points: 76
Bath room vent
Hi all, I just put a new roof on my house. Had a couple of roof leaks. So today I went about replacing some water damaged drywall. When I opened up the wall. What I found was a vent pipe to the bathroom enclosed in the wall. Does not seem to be any mold or anything. But I know gas etc. can be dispersed into the wall cavity. Can I just extend this 2 inch pvc pipe up into the attic? Or does it have to go through the roof. I really don't want to be cutting holes in my new roof. I also can not afford to hire a plumber and a roofer at this time due to money constraints. Dang new roof had to have a lot more decking replaced which just about taped me out. As it is I am at a stand still till I get this figured out. Thank You for any and all suggestions, Charlie.
UFCreel is offline   Reply With Quote
Old 06-15-2016, 04:13 PM   #2
Rewards Points: 1,938
Re: Bath room vent
Runs through the roof and in some places must be 3 inch out the roof.
Old 06-16-2016, 10:21 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Re: Bath room vent
while I am not a big fan of them, you can opt with an AAV box with a access grill panel, Best through the roof but if not use the AAV. can not be mounted in attic or plume.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 06-16-2016, 01:57 PM   #4
Rewards Points: 76
Re: Bath room vent
Okay I think I got this figured out. Although I did find another stack vented up into the attic. So while I am up there i will put it through the roof too. I do have a question though. When I cut the hole in the roof. Can I use PVC pipe to vent outside? Also do I leave the pipe straight up or do I put an elbow on it? Seems easy enough.
Old 06-16-2016, 08:51 PM   #5
Re: Bath room vent
Straight up make sure about the roof penetration pipe size. Colder areas have larger pipe requirements. Ohio is 3 inch 12 inches below roof and 12 inches above as a minimal distance.
Old 06-17-2016, 06:30 AM   #6
Rewards Points: 76
Re: Bath room vent
Okay I see here in Illinois I need 3 inch pipe through the roof. Last question. How far from the eve of the roof must this be placed? Thank you all for the responses. Charlie.
Old 06-17-2016, 06:36 AM   #7
Rewards Points: 18
Re: Bath room vent
I have a similar issue and a question. If i have a 4 inch stack already exiting through the roof, can I cut into that stack, install a wye, and tie my new vent into that wye? This would obviously avoid the risk of cutting and sealing a new hole in the roof.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 06-17-2016, 08:54 AM   #8
Rewards Points: 127
You cannot run a bathroom vent fan into a plumbing stack. Putting a hole through a shingled roof with a proper hood and flange is not difficult and is leak proof .
jeffmattero76 likes this.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
jeffmattero76 (06-18-2016)
Old 06-17-2016, 01:25 PM   #9
Rewards Points: 76
Re: Bath room vent
In my case this is not a bath room fan vent. I believe it is the vent stack off of a bathtub. Can I just 45 over to the vent stack that goes through the roof? The thing is if I just go straight up I will only be about a foot and a half away from the eve the house.
Old 06-17-2016, 04:04 PM   #10
Re: Bath room vent
YEs you can. as long as we aint talking about a fart fan.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 06-18-2016, 06:05 AM   #11
Rewards Points: 76
Re: Bath room vent
Thank you!
Bath vent and outside objects wvphysics Building & Construction 2 06-30-2016 07:50 PM
HVAC Return Vent Alteration for Sound Proofing Job2Do HVAC 16 02-29-2016 08:35 AM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 10:26 AM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
