Bath Faucet Handle Has No Screw - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2015, 08:55 PM   #1
Rewards Points: 2
Bath faucet handle has no screw
Hot water is dripping on my bathroom sink widespread faucet. I bought it in Home Depot in 2008. I don't know the manufacturer as there is no markings on it. The handle is smooth and I can't find set screws or any cap on it. Can someone tell me how to remove the handle? Can someone tell me the manufacturer and model number?
I can't post links yet.
tinypic.com/r/20f3m8m/9
Thanks.
gx22 is offline   Reply With Quote
Old 11-04-2015, 09:47 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,682
I have no idea what brand that is but look for a small hole where you can insert a hex wrench to remove it. It could have a little button covering over it.
Old 11-04-2015, 10:08 PM   #3
griz's Avatar
Rewards Points: 572
There is a cap or set screw somewhere....
Look closer
griz is offline   Reply With Quote
Old 11-05-2015, 12:33 AM   #4
Rewards Points: 158
Kinda looks like this one
http://www.homedepot.com/p/Glacier-B...8004/203294809
If you go to their website, they also have an installation guide which should tell you where everything is and also has a diagram of the handle for maintenance. If it's not the same faucet, it should be a somewhat similar repair anyway.
First make sure you shut off the water valve. Take off the tiny cap on the handle, which will have an allen wrench mini screw. Taking off this screw should release the handle and you can replace the cartridge. If it were me, I would definitely take the entire handle plus cartridge to Home Depot and tell them what's going on. They can help you identify the faucet and if it is Glacier Bay, it is their home brand of faucet. They should be able to give you any free replacement parts or whatever you need. If the part doesn't work, they should give you a full equal or similar replacement because of the lifetime warranty. Trust me, I've done it before.
mikemark8808 is offline   Reply With Quote
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 38 01-16-2018 03:07 PM
Kohler single handle shower faucet loose Liv Plumbing 8 11-13-2015 04:22 PM
Broken Screw in Shower Handle Stem lynnelist Plumbing 2 07-09-2014 04:21 PM
removing stripped 3/32 allen screw from single handle delta shower faucet miguelsalcido Plumbing 3 05-04-2012 12:42 AM
faucet handle won't come off pkhalsa Plumbing 9 06-20-2011 08:39 AM
