Basement Watchdog - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2017, 06:29 PM   #1
Rewards Points: 20
I have the Basement watchdog backup sump pump. I had the unit and battery unplugged for a month and I hooked it back up and says battery is 25% but it's not charging. I tested the fuses and have continuity. I then unplugged everything, checked the battery and it is 12.45 volts. Plugged everything back in and the unit now says it's 100% fully charged. Any ideas what gives? Obviously it's not charged at 12.45 volts and it doesn't say it's charging. Any ideas?
Shelby2098 is offline   Reply With Quote
Old 12-24-2017, 06:59 PM   #2
hkstroud's Avatar
Rewards Points: 6,694
Re: Basement watchdog
See below.
Read frequently ask questions. Pay particular attention to:
How long does it take to fully charge a battery after it has been used extensively?
A 12V battery will show 12V approximately unless it is totally discharged. Voltage does not indicate the status of charge or discharge.
Easiest way to measure the state charge is with a hydrometer.
Also check water level of each cell.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 12-24-2017, 07:06 PM   #3
Rewards Points: 20
Thanks for the link. I'm more concerned of the inconsistency of the unit telling me that the battery is 25% and not charging and then 100% and fully charged.
Old 12-24-2017, 07:51 PM   #4
hkstroud's Avatar
Make sure that post on the battery are clean and cables are secure. The charger is probably using the resistance it meets to determine the state of charge.
A hydrometer doesn't cost much (automotive store).
Harold,
Old 12-24-2017, 09:19 PM   #5
Rewards Points: 20
If I have one of the maintainance free marine batteries, can I still get to the acid?
Heat/cool a basement Todd1561 HVAC 8 02-26-2014 10:33 PM
Prep to finish basement...Sub Panel? Thisgrub4u Electrical 14 01-06-2014 11:10 PM
septic pump for basement toilet denemante Plumbing 4 02-13-2013 10:42 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
