Basement Upflush Shower Height Required Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2017, 11:16 AM   #1
Basement upflush shower height required question
How much higher will my shower floor need to be from my entry point into my upflush Reservoir ?
I have an everbilt upflush toilet Reservoir that my drain pipe for my shower can be plugged into but it needs to be plugged in six and a half inches up from the bottom of the reservoir.
I have 90 inches from floor to ceiling to work with.
I'm trying to figure out how much higher I am going to need to make my shower floor above the six and a half inch entry point of my everbilt toilet Reservoir.
I plan to put the shower right next to the toilet to minimize the Run.
Considering maybe not using the everbilt toilet Reservoir that I have and buying a saniflo toilet system because that shower drain pipe enters the saniflo system only an inch and a half from the ground and the saniflo rep said that some customers install the shower drain without P trap when clearance is an issue. I know it will fail code without a P-trap but I am not real worried about code in my basement.
The thinking is that since the saniflo has a flap valve that opens and closes when the shower is in use and not in use that Vapors should not be much of a problem and it would be nice to have the tallest shower I can possibly have in the basement with the smallest Step Up.
I'm trying to determine if I should buy the saniflo or just use the everbilt that I have. Here is a picture of the everbilt.
Another thought is to excavate out four or five inches of my basement and put the everbilt down into that and backfill the perimeter with concrete. I have a radon mitigation system in my basement but I don't know if radon will be still sealed out if I go that route. I'm also worried about water intrusion when we have wet springs or fall. The everbilt does not have any flap valves so I will definitely be using a P trap with that one.
Thoughts on shower floor elevation required and or going with the saniflo without a p trap?
Drewbabich is offline   Reply With Quote
Old 06-16-2017, 11:17 AM   #2
Pic included
Basement upflush shower height required question-screenshot_20170616-115843_1497629800201.jpg
Old 06-16-2017, 12:37 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 32,020
Re: Basement upflush shower height required question
1/4 slope per foot of run should do you fine. So 3 feet away 3/4 inch higher at the shower.
Old 06-16-2017, 04:39 PM   #4
Rewards Points: 1,952
How high is the external fixture tie in on your unit? That is where you start you also must vent the shower and the unit itself to outside air.
I would go with this
https://www.amazon.com/Saniflo-SaniP.../dp/B009R95NIE
Old 06-16-2017, 05:18 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,886
Besides your required fall to the unit and the unit inlet height, most jurisdictions reuire a 2" shower drain (no tub).
Sorry, I don't have a 2" p trap to measure, but I suspect that trap will take up 6-7 inches depth , depending on the shower floor drain style. (Now that is not necessarily additive to how high your shower base has to be.... it is probably a minimum.... as the trap arm obviously is maybe only several inches below your shower base.)
You might check whether you can use 1.5 as a drain in your area.... and you may want to pick up the 1.5 and 2" P traps and actually measure them to determine the depth you'll have to raise your shower floor.
Good luck
EDIT: I don't have any experience with those units.... but I would hate to not put in a P trap, build a whole shower, and then find out I really needed it. (Gguess, I'd want some pretty good advice and experience to count on that saniflow flapper.)
MTN REMODEL LLC is offline   Reply With Quote
Upflush toilet can I plumb a sink going to a shower and then the shower feeding into Drewbabich Plumbing 2 06-11-2017 01:50 PM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
basement shower question newfieblue Remodeling 5 12-04-2012 05:23 AM
