Basement Toilet Drain Too Close To Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Nealtw
Old 04-25-2018, 06:55 PM   #1
Rewards Points: 18
Question
Basement toilet drain too close to wall?
I posted yesterday about identifying some rough-in plumbing, which is pretty much solved now (thank you) but made me realize another potential issue. I don't see how I could maintain 12" from finished wall to center of toilet drain..
So.. could I get away with something like 9"?! Are there toilets that could fit that?
OR.. instead of framing in a wall against the foundation/insulation there, maybe I could just do strapping and drywall on it (somehow) to try to maintain those 12 inches? (if it's that important to maintain 12")
Thoughts? Thanks all!
mistersilver is offline   Reply With Quote
Old 04-25-2018, 07:04 PM   #2
retired framer
Rewards Points: 17,562
Re: Basement toilet drain too close to wall?
Turn the studs flat in the bathroom or Toto makes a toilet that is 10 inch and will work at 9"
https://www.solidtoilet.com/8-9-inch-rough-in-toilet/
Guap0_ likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
mistersilver (04-25-2018)
Tags
plumbing , toilet
Drain tile before basement backfill CTSNicholas General DIY Discussions 40 05-02-2017 09:50 PM
Low profile basement toilet drain fittings...?? Jhn1703 Plumbing 2 02-21-2013 04:35 PM
septic pump for basement toilet denemante Plumbing 4 02-13-2013 10:42 AM
Can I Move Toilet Drain Into Wall? Toilet Bowl Plumbing 16 06-28-2012 03:06 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
