Basement Stub In - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 01-18-2018, 06:32 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 254
Re: Basement Stub In
This the layout I see.
Wet vent the lav on the toilet vent
Enlarge the box to accommodate the tub trap
Nealtw likes this.
Old 01-18-2018, 06:36 PM   #17
retired framer
Rewards Points: 15,432
If the tub trap has to be moved frame the wall against the foundation first to avoid any screw ups.
Old 01-18-2018, 06:55 PM   #18
Rewards Points: 14
What is a lav vent?
jj16605 is offline   Reply With Quote
Old 01-18-2018, 07:02 PM   #19
retired framer
Originally Posted by jj16605 View Post
What is a lav vent?
Lav= sink.
Old 01-18-2018, 07:21 PM   #20
Rewards Points: 14
Here is the closest thing that resembles a vent that I can see. NOt in the ceiling but does come down from one of the other bathrooms
Old 01-18-2018, 07:27 PM   #21
Rewards Points: 14
This is 3in PVC
Old 01-18-2018, 08:38 PM   #22
retired framer
This is 3in PVC
That would be the upstairs toilet and everything else where it exits the building. @TheEplumber Will want to see anything else you have that goes thru the ceiling.
Old 01-18-2018, 08:46 PM   #23
Plumber
Rewards Points: 254
Every plumbing fixture requires a trap.
Every trap needs to be vented.
Some fixtures can drain into another fixture's vent (wet venting). This appears to be the case with your toilet. I say appears because that is the way I would plumb your layout- based on the info provided by you so far.
We need to find a 2" minimum vent line in your basement ceiling or walls. This is needed to vent your basement bathrm through the roof.
The 3" as mentioned, is a drain stack for upper floor plumbing. It is no help in your situation
Old 01-18-2018, 09:33 PM   #24
Peace be with you
DR P's Avatar
Rewards Points: 1,860
that toilet is really tight to your tub dam;
it will barely work with 30" tub base & 2X4 wall
but if a 32" tub enclosure is used with 2X4 wall
from center line of toilet to tub dam measures 11"...
if your looking at any 1-piece tub shower enclosure;
I believe 32" is max width & you're better off
furring wall & insulating with best R value available
Peace
DR P is offline   Reply With Quote
My Basement Journey tojo78 General DIY Discussions 8 06-23-2017 07:53 PM
Crawlspace Encapsulation / Basement Vents and Registers Anomaly0 HVAC 0 06-13-2016 01:41 PM
Heat/cool a basement Todd1561 HVAC 8 02-26-2014 10:33 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
