Basement Shower Sewer Smell - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 01-26-2018, 12:25 PM   #16
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Basement shower sewer smell
did they camera main drain?
what about washer drain?
that pumping action could siphon shower if
those two drains tie together & vent
for shower location/function questionable
Peace
DR P is offline   Reply With Quote
Old 01-26-2018, 12:46 PM   #17
Rewards Points: 58
The just camerad the shower.
But I was running the water in the sink the washer goes into.
Christians1 is offline   Reply With Quote
Old 01-26-2018, 01:28 PM   #18
Peace be with you
DR P's Avatar
you can test yourself,
next time before your washer dumps,
go to shower drain w/flashlight &
watch if trap level fluctuates up/down
as pumping action is created by washer
Does sink drain easily handle all water discharged from washer without backup?
Peace
COLDIRON likes this.
Old 01-27-2018, 11:04 AM   #19
Rewards Points: 58
Yeah I see the water just vibrate a little but doesn't look like it goes up or down.
But, I measured the water then went to bed with no activity over night and measured in the morning and it was like 3 inches lower. I think it has to be a slow leak.
My neighbor does concrete. Would a plumber work with me on this so I can save money.
I dig it out.
Plumber fixes pipe
I put dirt back and concrete
Old 01-27-2018, 11:20 AM   #20
Peace be with you
DR P's Avatar
I dig it out.
Plumber fixes pipe
finished showers have pans incorporated into drainage...
are saying this is a rough concrete floor (without any tiling)?
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
Old 01-27-2018, 01:58 PM   #21
Rewards Points: 58
Ok yeah I thought there are pans. This shower floor has tiles. I assume the pan is under the tiles?
Old 01-27-2018, 05:07 PM   #22
Peace be with you
DR P's Avatar
yes & pan incorporates/rolls up behind tile shower's vertical surfaces along with threshold...
therefore entire bottom 1/3 of shower will need replacing (if not entire shower)...
I've done this for older clients on budget when pan failed
but it is a pain and most tile contractors would not even consider this ...
they get paid to put in tile & there is more money involved with gutting shower = more tile...
Peace
Old 01-27-2018, 06:06 PM   #23
Rewards Points: 58
Ah got it. Man this is bad timing. I can't sell the house this way.
I spoke with my realtor and she said to fix it and she will mention it to buyer and say we did fix it.
But I wonder if they would want to be involved as they may want to just retile the whole shower and not just the bottom 1/3.
The person buying the house is a 29 year girl. I do not want to put her in a bad spot with this issue, so I do want to do the right thing. Just hope this does not make her back out.
Old 01-27-2018, 06:13 PM   #24
Guapo
Rewards Points: 11,950
Christian, let's start from the other end & work backwards. That drain is supposed to go into the city sewer or into a septic tank. However, in some early builds, the drains went directly into the ground or a line into the gutter near the curb. Have you traced that line to the end wherever it may take you? Do the other showers drain into a visible 4" pipe?
Guap0_ is offline   Reply With Quote
Old 01-27-2018, 06:19 PM   #25
Peace be with you
DR P's Avatar
try the vegetable oil test
Pour at least 8 oz into trap
& monitor level for week
while communicating forward
knocking off value of new shower
may be acceptable to new buyer
especially since drain can be plugged in interim
Peace
Old 01-27-2018, 09:22 PM   #26
Rewards Points: 58
It does drain to the city sewer. Near the sidewalk there is a 4" pipe. When I run shower I can put my ear to it and here water.
The up stairs shower drains into a 2" pipe then over to a large cast iron vertical stack.
I can't see where the basement pipe goes into.
Ok I'll try the oil.
Old 01-28-2018, 11:48 AM   #27
Rewards Points: 1,058
For the record, you should use mineral oil and not vegetable oil in a seldom used trap. The vegetable oil can and does go rancid and will smell just as bad as the sewer gas!
For a basement shower that is rarely used, is it really worth the expense to bust up the concrete to look for a leak that may or may not even be there? If it was me, I'd go with the $30 trap guard, disclose it to the buyer and call it done.
NotYerUncleBob2 is offline   Reply With Quote
Old 01-29-2018, 06:27 AM   #28
Rewards Points: 2,074
Peace
" Could be the venturi effect"
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 01-29-2018, 07:17 AM   #29
Guapo
Christian, where the basement pipe goes is most important. Can you obtain a plumbing plan?
Old 01-29-2018, 10:33 AM   #30
Rewards Points: 58
I did a test last night. Measured the water level in the trap. Went to bed. Then checked it in the morning. We did not run water or flush any toilets. It went down just over 1 inch in 6 hrs.
If it's going down without running water or flushing toilet or doing wash It has to be a leak?
I'm not sure where to get the plans to show where/how the pipes run.
Sewer gas smell in basement utility sink curttard Plumbing 24 10-15-2015 06:24 AM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 11:13 AM
sewer smell in basement bathroom AndyH24 Plumbing 22 12-24-2010 04:37 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
