Basement Shower Into Open Floor Drain Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2015, 08:47 AM   #1
Rewards Points: 28
Basement shower into open floor drain question
Hi all,
Lurker here with a question for yall:
I have a drop-in shower in my basement which i'm looking to convert to a full framed in and tiled shower but the plumbing has me a little concerned. I'd like to re-use it but not sure if its done to code.
The shower sits on 2x4s and under the shower drain the concrete has been knotched out a few inches to accomodate a P trap. From the P trap the line slopes down, into the concrete and comes out at the open floor drain which is clay.
Heres a quick picture. Can I re-use this? Or do I need to break up the concrete and start searching for the drain pipes?
kwasley is offline   Reply With Quote
Old 10-23-2015, 08:51 AM   #2
Rewards Points: 28
can't post links yet...
Old 10-23-2015, 08:52 AM   #3
Rewards Points: 28
Old 10-23-2015, 04:14 PM   #4
Rewards Points: 1,952
Without knowing what state you reside in we do not know what plumbing code is applicable.
Old 10-23-2015, 05:29 PM   #5
Rewards Points: 28
ONTARIO, Canada. Thanks!
Old 10-23-2015, 08:22 PM   #6
Sorry I'm not learned in Canadian plumbing code.
Old 10-23-2015, 11:53 PM   #7
Rewards Points: 114
you cannot have a shower draining into a floor draining, it is against code in Canada. You will need to break open the concrete to find where you can tie in, do you have a toilet and sink in the basement also? also you will need to figure out a way to vent the shower.
Chrisathome is offline   Reply With Quote
The Following User Says Thank You to Chrisathome For This Useful Post:
ben's plumbing (10-24-2015)
Old 10-24-2015, 06:06 AM   #8
Rewards Points: 28
thanks. this is what i figured. yes, there is a sink and toilet right next to it. guess ill be breaking up concrete and digging for a drain.
The Following User Says Thank You to kwasley For This Useful Post:
Newb DIY'er -basement drop ceiling question mike dub Remodeling 3 02-18-2013 07:37 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Basement Shower smells wdodds Plumbing 7 11-15-2009 08:31 PM
Basement shower install howto greight Building & Construction 4 04-13-2009 04:19 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
