Basement Shower Drain Rough In Question - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 06-21-2017, 11:22 PM   #1
Network Geek
Rewards Points: 14
Basement Shower drain rough in question
Hi,
I would like to start my basement bathroom project. The plumbing was roughed in and PEX water lines were put in place. I have decided to do a tiled shower and my first hurdle is understanding the shower drain pipe in this pic.
Here are my questions (feel free to link a way, I'm sure this has all been asked before)
1) Do I need to install a P-Trap? To my knowledge this pipe feeds into my sealed pit which the toilet will feed into as well. Seems like I would need one.
2) The one example I found online showed this hole being filled with Slag Sand or Paver Base Aggregate Fill..is that cool?
3) Does the drain kit need to be supported by anything else but the backfill material? Meaning, can I install it right in the middle of this square or should it partly hang over the base floor?
Thanks in advance.
Jason
dive_instructor is offline   Reply With Quote
Old 06-22-2017, 05:03 AM   #2
Rewards Points: 898
Re: Basement Shower drain rough in question
Originally Posted by dive_instructor View Post
Hi,
Attachment 392409
Thanks in advance.
Jason
There might already be a trap. Dig out. The pipe sticking up might also be loose. As well as the trap. The correct way to rough in at construction is to leave a big hole like you have there and loose fit a trap and plugged standpipe because the a rough in plumber does t know the exact location you'll need it.
Is that a 2" ID pipe?
BIG Johnson is offline   Reply With Quote
Old 06-22-2017, 05:19 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,490
Agree with BigJohnson, pipe must be 2" for a shower. I don't understand the OSB and the gravel. They just don't go together. Is there a subfloor over concrete?? The trap is already in the gravel. You can dig it out and find it.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 06-22-2017, 05:52 AM   #4
Rewards Points: 898
It looks like some kind of dry floor product. There's something attached to the bottom. Probably 2x2 T&G panels. I might cut it away from where the tiled shower is going. Maybe it doesn't matter?
Old 06-22-2017, 06:03 AM   #5
Naildriver
chandler48's Avatar
Ah, yeah, it could be a prebase for the shower itself. Prior to tarpaper and preslope.
Larry......
Old 06-22-2017, 07:48 AM   #6
Network Geek
Rewards Points: 14
Thanks for the replies. That makes sense. I will check the pipe size tonight, but im pretty sure it's 2".
That is my basement subfloor and the shower will be built on top of it. I have watched a few videos and their seems to be plenty of examples of building a shower...should be fun.
Old 06-22-2017, 05:51 PM   #7
Naildriver
chandler48's Avatar
"FUN" is a word.
Larry......
Old 06-22-2017, 07:58 PM   #8
Network Geek
Rewards Points: 14
2" pipe and P-trap. Pipe is not glued.
You can see my home corrugated drain too in the pic.
Mike Milam likes this.
Old 06-23-2017, 05:33 AM   #9
Naildriver
chandler48's Avatar
Yep, that's how it should be. if you remove more gravel the trap will be more exposed and you can move it to where you want it for your shower drain location.
Larry......
Old 06-23-2017, 07:10 AM   #10
hkstroud's Avatar
Rewards Points: 6,694
Don't want to be the party pooper but it looks to me that you are set up for a tub, not a shower.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 06-23-2017, 08:10 AM   #11
Network Geek
Rewards Points: 14
Hi, can you explain please...isnt a drain a drain?
Old 06-23-2017, 03:51 PM   #12
Naildriver
chandler48's Avatar
A drain IS a drain. The final positioning and gluing of the pipes and traps will set the location. You can always overlay a piece of OSB with a correctly positioned 2 1/2" hole to go over the pipe and offer support for the packed pan, assuming that is what he is doing.
Larry......
Old 06-23-2017, 03:56 PM   #13
retired framer
Rewards Points: 15,210
If the pipe is in the wrong place, rent borrow or steel a jack hammer and move it.
Nealtw is offline   Reply With Quote
Old 06-23-2017, 04:28 PM   #14
Rewards Points: 898
As long as its 2" it's suitable for a shower.
Are you doing a fiberglass pan or making your own out of deck mud?
TheEplumber likes this.
Old 06-23-2017, 05:15 PM   #15
Network Geek
Rewards Points: 14
Hi, the position of the drain is fine. I am tiling the whole shower...so if you have a great video or link that shows the right way to do it I will follow that.
I saw a system from Schulter to waterproof the shower..pre-tile, but it will cost over $1k just for that. Looks neat, but I don't think I want to go that route. I think I'm more handy than that.
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Basement Bathroom Rough In LarryM Plumbing 5 12-05-2014 03:45 PM
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
tapping into basement tub drain muellertr Plumbing 11 02-07-2013 01:38 PM
Basement Shower Remodel Question mdsnj Kitchen & Bath Remodeling 3 02-27-2010 12:16 PM
