Basement Shower Drain + Main Cleanout Out Backed Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2015, 10:11 PM   #1
Rewards Points: 58
Basement shower drain + main cleanout out backed up
I was sealing up areas in the attic on Saturday including the main vent stack where it exits through the roof. The next day the basement shower drain is backing up and also the main cleanout whenever any huge amount of water is draining ( main floor bathtub and dishwasher on Sunday morning). Could this be due to me sealing that waste vent. I didn't seal the pipe opening but where it enters the vent boot. Just seems odd that this happens a day after I was in the attic. Any help? Is it just coincidence and it is a big clog.
saxsquad29 is offline   Reply With Quote
Old 11-15-2015, 10:15 PM   #2
Rewards Points: 1,860
Nope just weird things happen. Get your main cleaned.
The Following User Says Thank You to Ghostmaker For This Useful Post:
saxsquad29 (11-15-2015)
Old 11-15-2015, 10:26 PM   #3
Rewards Points: 58
I did have main line cleaned out about 1 month ago. But at that time the problem was only limited to basement shower drain backing up when washing clothes. Now the main cleanout is backing up after shower drain backs up. This happens when main floor bathtub drains, toilet, basically everything.
Old 11-16-2015, 09:36 AM   #4
Rewards Points: 58
If my main line is clogged, is this something I could snake myself. Tried snaking the main CO with a cheap manual snake with drill attachment. Couldn't get anywhere with it. Could I rent something more powerful or is this best left to the pros?
Old 11-16-2015, 10:10 AM   #5
Rewards Points: 352
Pro's. Use a local service plumbing company not one of the nationwide franchises. If the plumber works on commission it will be in his own interest to sell you products and services you may not need.
plumberinlaw is offline   Reply With Quote
Old 11-16-2015, 06:18 PM   #6
No Roto anyname company call a local service shop.
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Shower Drain 325_man Plumbing 9 06-12-2014 06:34 AM
Water backup into basement floor drain after jetting lateral and sanitary sewer sm2327 Plumbing 4 04-01-2013 12:18 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Basement bathroom shower drain conversion coyotewaits Plumbing 1 01-08-2009 01:17 AM
