Basement Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-22-2016, 12:09 PM   #1
Rewards Points: 12
Wanted to humbly ask some guidance. Homeowner before us added an ugly concrete shower base, that was too ugly to tile, etc (pic below). So I took it out hoping to rebuild the shower base, frame and waterproof the walls and then tile. Well after taking out the curb, and base much to my dismay I found that the shower drain was just sitting in a massive hole inside the drain pipe it was tapped into - no p trap/no nothing (only attached via the poured concrete). As such I have attached pictures of what the hole in the pipe looks like and prior to moving forward I wanted to obtain some guidance. Can the existing pipe be cut and attached rubber boots/couplings to pvc and then tie in a new drain and trap to the pvc? Or is there another way I should go about this? All help is needed. I am in Indiana - any coding issues I need to be made aware of as well would be helpful. Thank you in advance.
likopass is offline   Reply With Quote
Removal of Metal Shower Drain From Above jreddiv Kitchen & Bath Remodeling 2 05-16-2016 11:15 AM
Basement floor drain as shower drain? bvawd Plumbing 9 03-11-2016 10:10 AM
basement shower drain firetruck12 Plumbing 3 08-17-2013 06:50 PM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 12:49 AM
Basement bathroom shower drain conversion coyotewaits Plumbing 1 01-08-2009 01:17 AM
