Basement Remodel / Pluming Cost - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2016, 01:36 PM   #1
Rewards Points: 2
All,
I am finishing my basement and as part of it, putting a full bath with laundry room. I am in greater Boston area and following is the price I received from a local master plumber to get the job done. I am just trying to validate with this forum if these prices are reasonable or I should keep look for someone else.
Bathroom is quite small, and bathroom will be below first floor bathroom so there is easy access to existing plumbing. Job will include cutting through the concrete for the job as well as putting a below ground sewage ejector pump.
1.Move water heater few inches and turn it director so it can be framed properly in mechanical room - $900
2.Revamp 1 Duct (10 feet) to gain more space/room $1000
3.Full Bath with ejector pump rough in as well as finish (installing fixtures) - $6000
4.Relocate laundry connections (Gravity) as well as install new stable washer / gas dryer $1500
Are these prices reasonable?
amitp401 is offline   Reply With Quote
Old 11-14-2016, 02:04 PM   #2
Rewards Points: 1,528
Re: Basement Remodel / Pluming Cost
get multiple bids.. then you can determine what is reasonable or not..
ryansdiydad is offline   Reply With Quote
Old 11-14-2016, 03:58 PM   #3
Rewards Points: 1,860
Do make sure permits and inspections are part of your bids.
Old 11-16-2016, 06:55 AM   #4
Rewards Points: 1,288
Min 3 bids and itemized plus you call their insurance company to verify. What is your area, include material and labor? At least that much and I may be able to share experiences of being screwed.
carpdad is offline   Reply With Quote
Tags
basement bathroom , pluming
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Cost to install HVAC venting in unfinished basement BaconK5 HVAC 6 09-24-2014 10:09 PM
Basement remodel, help with an efficient layout? (diagram incl.) Dave88LX Remodeling 1 11-10-2011 03:36 PM
Basement Shower Remodel Question mdsnj Kitchen & Bath Remodeling 3 02-27-2010 12:16 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
