Basement Laundry Room DWV - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2015, 12:03 PM   #1
CZone's Avatar
Rewards Points: 46
Thumbs up
Hello everyone. So I have moved onto the basement projects and the first order of business is the laundry room. I think I have the right idea, just looking for some reassurance. Any comments/critiques appreciated.
Note that the vent will tie in to a bathroom group on a separate floor.
CZone is offline   Reply With Quote
Old 02-01-2015, 12:20 PM   #2
Rewards Points: 1,952
Your pump should discharge to a 4 inch drain if you have one. The DFU load is far to great for a 2 inch drain.
The Following User Says Thank You to Ghostmaker For This Useful Post:
CZone (02-01-2015)
Old 02-01-2015, 12:54 PM   #3
CZone's Avatar
Rewards Points: 46
Thanks for the quick reply. I guess I assumed since the pump requires a 1.5" discharge, a gravity drain 2" would be more than enough. Unfortunaly the connection sticking out of the wall is 2" (just beyond that is the 4" soil stack) and the pipe is buried in concrete. Is there anyway to make this setup work with a 2" drain to work with??
I dont know if it matters, but the sink will not be discharged into by any appliances. Just water from the tap.
Old 02-01-2015, 01:24 PM   #4
Rewards Points: 1,910
What if you drain the washer into the ejector pump also. Then the 2" is all ejector pump discharge pipe and gravity drain starts at your 4".
The Following User Says Thank You to jogr For This Useful Post:
CZone (02-01-2015)
Old 02-01-2015, 01:56 PM   #5
CZone's Avatar
Rewards Points: 46
That's not a bad idea actually, but I was really hoping to gravity drain the washer to prevent the washer from overflowing into the basement if the ejector pump crapped out.
That made me think that I could just make a separate branch into the 4" stack (above the cinderblock wall)...it wouldn't be the most efficient use of PVC, but it would work...
Old 02-01-2015, 02:14 PM   #6
Isn't there a 4 inch clean out plug where it go's out?
CZone (02-01-2015)
Old 02-01-2015, 02:36 PM   #7
CZone's Avatar
Rewards Points: 46
I live in a split level home and the area where it goes out is buried. The only way to make another connection would be to cut into the main stack. Do you see any other problems with this layout?
Old 02-02-2015, 02:20 PM   #8
CZone's Avatar
Rewards Points: 46
I updated the layout with the changes.
Old 02-02-2015, 05:50 PM   #9
just make sure where the washer vent and sink vent join your 6 inches abovve the highest flood level rim.
Old 02-03-2015, 06:06 AM   #10
CZone's Avatar
Rewards Points: 46
Yes that horizontal connection is about 20" above the standpipe.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Moisture / Mold In Basement Rec. Room jr991 Building & Construction 3 08-18-2013 08:48 PM
Plumbing Questions - Convert Upstairs Laundry Room to Bathroom mjp24coho Plumbing 3 01-02-2012 11:16 AM
Creating a basement laundry room. Mn_Shooter Plumbing 1 01-06-2011 08:02 PM
Small basement room moisture ? timrec Building & Construction 2 08-25-2010 05:14 AM
