Basement Floor Drain As Shower Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2016, 11:17 PM   #1
Basement floor drain as shower drain?
I am in the process of planning out a small basement bathroom. I have an existing floor drain that is only 12" from the main stack and is already in a good location for the shower drain. Will the main stack serve as a vent being so close to the drain? Can I use the floor drain for the shower drain? In Utah if it matters.
bvawd is offline   Reply With Quote
Old 03-10-2016, 12:14 PM   #2
Rewards Points: 1,950
Instead of making a chopped up shower why not just install a shower on a wooden base then just indirectly drain it to the floor drain? Make that area a linen closet to keep access to the floor drain in case you need to open it up at a later date.
Or just use one of these http://www.mustee.com/product-lines/shower-stalls/
Ghostmaker is online now   Reply With Quote
Old 03-10-2016, 12:54 PM   #3
SHEPLMBR's Avatar
Rewards Points: 178
Are you sure your floor drain is not daylighted?
SHEPLMBR is offline   Reply With Quote
Old 03-10-2016, 01:19 PM   #4
WhatRnsdownhill's Avatar
Rewards Points: 2,220
what are you gona do about a toilet?
WhatRnsdownhill is offline   Reply With Quote
Old 03-10-2016, 04:00 PM   #5
No, not 100%. I assumed since it's so close to the main stack that it is tied in. Can it be verified with a scope?
Old 03-10-2016, 04:02 PM   #6
I had considered draining it indirectly to the floor drain. Just want to make sure it's 'legal' to use the floor drain as the shower drain.
Old 03-10-2016, 04:10 PM   #7
Planning to put a wall-hung toilet to the left of the stack and reconfigure the cleanout near the floor (where the ABS is currently going into the stack) to accommodate the toilet, the existing ABS and leave an accessible cleanout.
Old 03-10-2016, 10:14 PM   #8
Rewards Points: 114
Ive gone to houses which in the basement that had a raised floor, fully plumbed for a bathroom tied into the cleanout in the base of the stack. This is definitely a handyman special but its very possible to do. I would do this instead of indirectly draining the shower into the floordrain.
Chrisathome is offline   Reply With Quote
Old 03-11-2016, 06:03 AM   #9
SHEPLMBR's Avatar
Rewards Points: 178
I would make sure it is not daylighted and there is a trap below the floor
Old 03-11-2016, 10:10 AM   #10
Thanks, everyone, for the advice and suggestions. I'll get the sledgehammer and do it properly.
basement shower drain firetruck12 Plumbing 3 08-17-2013 06:50 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 12:49 AM
Basement bathroom shower drain conversion coyotewaits Plumbing 1 01-08-2009 01:17 AM
