DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Plumbing (https://www.diychatroom.com/f7/)
-   -   Basement floor drain as shower drain? (https://www.diychatroom.com/f7/basement-floor-drain-shower-drain-375754/)
bvawd 03-09-2016 11:17 PM
1 Attachment(s)
I am in the process of planning out a small basement bathroom. I have an existing floor drain that is only 12" from the main stack and is already in a good location for the shower drain. Will the main stack serve as a vent being so close to the drain? Can I use the floor drain for the shower drain? In Utah if it matters.
Ghostmaker 03-10-2016 12:14 PM
Instead of making a chopped up shower why not just install a shower on a wooden base then just indirectly drain it to the floor drain? Make that area a linen closet to keep access to the floor drain in case you need to open it up at a later date.
Or just use one of these http://www.mustee.com/product-lines/shower-stalls/
SHEPLMBR 03-10-2016 12:54 PM
Are you sure your floor drain is not daylighted?
WhatRnsdownhill 03-10-2016 01:19 PM
what are you gona do about a toilet?
bvawd 03-10-2016 04:00 PM
No, not 100%. I assumed since it's so close to the main stack that it is tied in. Can it be verified with a scope?
bvawd 03-10-2016 04:02 PM
I had considered draining it indirectly to the floor drain. Just want to make sure it's 'legal' to use the floor drain as the shower drain.
bvawd 03-10-2016 04:10 PM
Planning to put a wall-hung toilet to the left of the stack and reconfigure the cleanout near the floor (where the ABS is currently going into the stack) to accommodate the toilet, the existing ABS and leave an accessible cleanout.
Chrisathome 03-10-2016 10:14 PM
Ive gone to houses which in the basement that had a raised floor, fully plumbed for a bathroom tied into the cleanout in the base of the stack. This is definitely a handyman special but its very possible to do. I would do this instead of indirectly draining the shower into the floordrain.
SHEPLMBR 03-11-2016 06:03 AM
I would make sure it is not daylighted and there is a trap below the floor
bvawd 03-11-2016 10:10 AM
Thanks, everyone, for the advice and suggestions. I'll get the sledgehammer and do it properly.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
