Basement Bathroom Rough In Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2017, 10:14 AM   #1
Rewards Points: 12
Basement Bathroom Rough in Help
Hello. I am finishing a basement bathroom with the rough in put in by the builders years ago.
I noticed that there is not a separate drain for the bathroom sink and was wondering if the vent could be used as a drain as labeled in the first picture.
my second question is that I need to move the shower drain from where it is now as. can I do this by digging the rocks out and hammering out the concrete where the drain needs to go then cutting the existing shower drain and putting in a 90 degree elbow connected to a longer pvc pipe that leads the drain to where it needs to go then again connected to a 90 degree elbow facing upward to get me to where I need the drain to be? ...sorry if that sounds confusing but I made a picture of what I am trying to do.
thanks for your help and advice!
Basement Bathroom Rough in Help-20170307_113609.jpg   Basement Bathroom Rough in Help-20170307_162601.jpg
bmangat1 is offline   Reply With Quote
Old 03-08-2017, 10:46 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,316
Re: Basement Bathroom Rough in Help
Ayuh,.... I don't see a problem with yer plans,....
A vent is a pipe that goes Uphill, a drain a pipe that goes Downhill, 'n nothin' says they can't be the same pipe,...
Basement Bathroom Rough In LarryM Plumbing 5 12-05-2014 03:45 PM
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 07:11 PM
Basement bathroom rough in question pmfleisch Plumbing 15 02-23-2013 09:20 PM
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 04:54 PM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 09:11 AM
