Basement Bathroom Plumbing - Rough In Backwater Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2016, 02:17 PM   #16
Rewards Points: 38
Originally Posted by Ghostmaker View Post
Looks like your toilet should be facing the back water valve when installed the lav to its right. You only need 24 inches in front of the toilet to the wall. It should work...
I see what you are saying, but then the BWV would be out in the middle of the room still... right (not the bathroom, but outside the bathroom)? I am lost with how the plumber or designer was intending this bathroom to be finished. Even if I put a wall right in front of the toilet and placed the BWV in some sort of little closet (unfinished inside) with a door, there is still a really weird configuration, as there would be a finished pole just right outside the bathroom door.
Or are you saying to build the wall right in front of the toilet, but keep the rest of the bathroom built out to the pole, like the shaded area in the diagram?
Appreciate your thoughts!
Steve_KC is offline   Reply With Quote
Old 01-15-2016, 05:02 PM   #17
Rewards Points: 1,860
All you need by code is 2 foot clearance from the porcelain in front of that toilet. Your option is if that will not work is move the toilet to a better position. You can buy toilets that rough in at 10, 12, or 14 to center off the back wall. So if you move the toilet drain you may clear the 24 inch in front of the installed bowel. I would suggest you purchase the toilet and just set the bowel on the drain so you can accurately determine your needs.
Old 01-15-2016, 11:44 PM   #18
Rewards Points: 352
If the cover of the BW Valve is flush with the floor why move it
plumberinlaw is offline   Reply With Quote
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
New basement bathroom plumbing help claydiy Plumbing 2 08-10-2013 08:29 PM
Plumbing a basement bathroom stradt03 Plumbing 15 11-20-2011 05:41 PM
Basement bathroom rough in........ Mills314 Plumbing 8 06-09-2011 09:22 AM
