Basement Bathroom Plumbing - Rough In Backwater Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2016, 09:29 AM   #1
Rewards Points: 46
Basement Bathroom Plumbing - Rough in Backwater Valve
I am trying to figure out how in the world to frame my basement bathroom. There is a backwater valve that would end up right in the middle of the room. I know that code requires access to this valve and most basement rough ins have this valve much closer to the sump pump or other mechanical area, not in the middle of the bathroom.
Any ideas for how I would be able to finish this bathroom with the BWV in the middle of the room?
What am I missing or am I looking at this all wrong?
Thanks for any help or answers you can provide!
Steve_KC is offline   Reply With Quote
Old 01-13-2016, 10:02 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,216
Ayuh,.... WHY is it in the middle of the room,....
Seems the answers are, move the valve, or move the room,....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Steve_KC (01-13-2016)
Old 01-13-2016, 10:13 AM   #3
Rewards Points: 46
Thanks for the quick reply! That is what I was afraid of. Are there any major concerns to jackhammer the floor to move the BWV 4-5 feet left of the current location? I assumed this valve is aligned to go straight out of house to city lines, so wasnt sure if injecting new bends or turns into the line creates any problems.
Old 01-13-2016, 10:40 AM   #4
Rewards Points: 46
Here are a few pics/diagrams of the basement and where the pipes are located.
Old 01-13-2016, 10:44 AM   #5
Rewards Points: 46
Sorry - Here are the pics...
Old 01-13-2016, 11:20 AM   #6
Bondo's Avatar
Ayuh,.... Yer drawin's don't say where the sanitary pipe exits the buildin',.....
The sump pump, is just a ground water trap, Right,..??
This toilet is goin' to drain into the sewer system, without a lift pump, Right,..??
Old 01-13-2016, 11:39 AM   #7
Rewards Points: 46
I am not 100% sure where they exit. I am guessing it would either be on the right, near the floor drain or left of the sump pump.
Correct!
Right!
Old 01-13-2016, 01:33 PM   #8
Bondo's Avatar
Ayuh,..... Ya gotta figure out exactly What's there now, where it is, 'n where it goes,....
Otherwise, how ya gonna hook up a toilet, without knowin' where it's goin',..??
Mappin' out the existin' system, should lead ya to where the pipes are, 'n where they go,...
Ya might have to pop a cap here, 'n there to see which direction, or not,...
But ya gotta know where stuffs at, Before ya begin,.....
Old 01-13-2016, 01:42 PM   #9
Rewards Points: 46
The plumbing rough in was all done when the house was built to code. If I dropped a toilet on there now, I think it is a safe assumption it would drain properly, but maybe I am missing something.
Ya might have to pop a cap here, 'n there to see which direction, or not,...But ya gotta know where stuffs at, Before ya begin,.....
I guess I am trying to figure out if I can simply extend the existing plumbing over 5 feet in the current configuration. Maybe what you are telling me though is that it is not that simple... I was thinking that I would leave everything, as is... just move the BWV 5 feet over and tie back into the same connection it was previously tied to...?
Old 01-13-2016, 01:46 PM   #10
Bondo's Avatar
Ayuh,.... I've never had to deal with a back up valve, but I believe it could be installed anywhere near the exit of the system,....
IF the pipe is goin' where ya want the valve, I don't see why it wouldn't work,....
I donno why they'd have put it in the middle of the floor in the 1st place though either,....
Old 01-13-2016, 02:24 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 248
The UPC plumbing code wants the valve on the basement part of the system. This means it may not be possible to move it.
You need to determine where the line is that serves the main floor. Look for an exterior clean out. This will tell you where the drain enters.
The rule I mentioned above may or may not apply per IPC. Do you know which code you use?
Old 01-13-2016, 08:34 PM   #12
Rewards Points: 1,928
Some for IPC the backwater valve is only for basement stuff nothing above that level can pass through it if it was installed correctly and that is a big IF.
Old 01-13-2016, 08:35 PM   #13
A few questions to answer
Are you on public sewer?
If so which side is the front of the house?
Are you on public water
Where does it enter the house?
Start looking in the water area for your main sewer cleanout.
Old 01-13-2016, 08:40 PM   #14
Looks like your toilet should be facing the back water valve when installed the lav to its right. You only need 24 inches in front of the toilet to the wall. It should work...
A round toilet is 16 inches from center of the hole to the front.
Old 01-14-2016, 02:10 PM   #15
Rewards Points: 46
Yes
Front of the house is the bottom center of the drawing above.
Yes
The main water line enters the house about 8 feet to the right of the sump pump through the wall on the bottom of the diagram.
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
New basement bathroom plumbing help claydiy Plumbing 2 08-10-2013 08:29 PM
Plumbing a basement bathroom stradt03 Plumbing 15 11-20-2011 05:41 PM
Basement bathroom rough in........ Mills314 Plumbing 8 06-09-2011 09:22 AM
