Basement Bathroom Plumbing Layout - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2015, 08:49 PM   #61
Rewards Points: 1,952
Hang in there this will be fun..
Old 01-14-2015, 07:44 PM   #62
Rewards Points: 165
If the distance from the sink drain/vent to the shower p-trap is only 3.5 feet, and the distance from the sink drain/vent to the toilet is also only 3.5 feet, can the sink vent be the only vent for the group? I will using a 2" vent for the sink. I also did some more measuring and messed around with the layout some more. I do have the depth to wye straight up for the toilet. Saves me from having to cut up more concrete.
chronojosh is offline   Reply With Quote
Old 01-14-2015, 08:06 PM   #63
YES. Distance to toilet doesn't matter.
Old 01-14-2015, 09:41 PM   #64
Rewards Points: 2,528
Why is it that the distance from the toilet to the vent does not matter?
hammerlane is offline   Reply With Quote
Old 01-14-2015, 09:49 PM   #65
Because the horizontal wet vent itself has no distance qualifiers. Only fixture and pipe size matter.
Bathroom group fixtures and DFU for pipe size.
If you think on it a bit the pipe from the toilet to the lav where he is venting is sized for 2 inch. The waste water will be on the bottom of the pipe the air is on the upper part thus maintaining the vent. The only distance that matters is the shower trap to it's vent which is the lav connection itself. Because the trap of the shower cannot be above the diameter of its pipe. At 1/4 inch pitch Minimal for 2 inch 8 foot is max distance. The shower drain to the lav is just a drain and not a wet vent. The only portion of this that is a wet vent is lav to toilet.
This is IPC not UPC IPC is a minimum based code.
The size of the wet vent is determined on all its fixture load 2 for shower 1 for lav. 3 total making him have 2 inch from lav to toilet. Under IPC he actually could run 1.5 inch to the shower it must be 6 foot from the lav vent. I never recommend using 1.5 inch on a shower it's just Piss Poor plumbing but I would have to pass it as long as there was only 1 shower head .
IPC also has shower trap sizing by amount of heads in the shower, Body showers and all that crap they install now.
Old 01-14-2015, 10:30 PM   #66
Plumber
TheEplumber's Avatar
Rewards Points: 290
The table you posted in post #51 is a UPC table and does not apply to IPC regulated states. UPC would require the toilet to have a vent within 6', the shower within 5'. or they could share a common vertical vent.
I believe only the latest UPC edition allows a limited amount of horizontal residential wet venting. I'm not real sure on that as my state has it's own code that is adopted from UPC within the last 2 years.
But prior to - I believe 2012- UPC did not allow any horizontal wet vents- except what they call "combination waste and vent" (an engineered system used in large floor layouts such as grocery store floor drains)
Clear as mud, huh
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-18-2015)
Old 01-15-2015, 03:41 AM   #67
Rewards Points: 165
Thanks! That's easier having to only deal with one vent pipe.
Old 01-15-2015, 06:20 PM   #68
That long post was trying to explain it all to hammerlane. When we changed code from our Ohio 1980 vent everything code to IPC we all had great doubts. AS it turned out it works fine last along time with one exception AAV use.
The Following User Says Thank You to Ghostmaker For This Useful Post:
TheEplumber (01-15-2015)
Old 01-15-2015, 09:26 PM   #69
That long post scared me....lol
Old 01-18-2015, 03:11 PM   #70
Rewards Points: 2
Not sure what areas heel inlet wouldn't be allowed they are approved in ipc and even here in nc where they use ipc but add millions of ammendments, hate to think there is stricter areas...But from how it looks toilet is about 10ft from stack, then lav about 3 ft from toilet and shower about 3 ft from lav so if taking lav vent through roof, no need to vent shower too...wouldn't hurt anything except add alot of extra un needed work, hell compromise and put a access panel to service shower valve and run studor vent to also be serviceable through access
Buz42812 is offline   Reply With Quote
The Following User Says Thank You to Buz42812 For This Useful Post:
chronojosh (01-18-2015)
Old 01-18-2015, 03:13 PM   #71
Rewards Points: 2
Please don't misunderstand, I'm really not trying to be a smartalec, I've been a licensed plumber for 22yr in fl, va, nc and sc....I'm not doubting what your saying I've just never encountered anywhere stricter than nc and or Charleston sc
Old 01-18-2015, 03:38 PM   #72
Plumber
Rewards Points: 290
You need to move out west then.....
Old 01-18-2015, 05:39 PM   #73
Rewards Points: 165
Thanks. Yeah those distances are about right. I just wanted to make sure that I get it right the first time. Don't want to have the inspector to have to come back and I certainly don't want to re do the work! Trying to still get the time to do it though. Hopefully this coming weekend will be my chance. Definitely having the sink vent be the only vent will save me a bunch of time and work.
Old 01-18-2015, 07:09 PM   #74
Rewards Points: 582
well let me tell you try working in and around pittsburgh pa ...inspectors follow the code to the tee...very little wiggle room...
Old 01-18-2015, 11:31 PM   #75
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
This thing still going !!
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Basement Bathroom Rough In LarryM Plumbing 5 12-05-2014 03:45 PM
Sewage pump for 1st floor bathroom, not basement? fetzer85 Plumbing 14 02-24-2014 07:56 PM
Replacing Basement Bathroom Plumbing snucky Plumbing 0 12-15-2011 05:42 PM
Basement bathroom plumbing diagram upnorth1 Plumbing 1 12-10-2010 04:00 PM
basement bathroom (concrete floor drain plumbing) amakarevic Plumbing 4 11-27-2007 05:37 AM
